It is currently Thu Jul 24, 2025 9:35 am
 Post subject: Impulse tacho rvi
PostPosted: Sun Jun 29, 2014 9:56 am
is anyone running a smiths RVI impulse tacho with electronic ign module?
Does it work properly? Any problems.
Some forums ive searched say its a no go...
Cheers....
Now with 2 extra ports!
 Post subject: Re: Impulse tacho rvi
PostPosted: Sun Jun 29, 2014 10:46 am
I believe a mod is needed to run the old RV1 (inductive loop) ones with electronic ignition.
http://www.nisonger.com/electric-tachom ... rsions.htm
I didn't think the mods needed were this drastic though!
The current impulse type ones work fine. I'd buy one of these if you want a Smiths, personally I'd buy something else with better damping.
http://minispares.com/product/Classic/G ... o%20search
PostPosted: Sun Jun 29, 2014 12:04 pm
Thanks doc. Thought it may be a problem. Might it try b4 I get something else though...
PostPosted: Sun Jun 29, 2014 9:39 pm
I have a smiths inductive loop tacho (after market, not clubman style) with A+ electronic ignition.
Works well with no mods.
PostPosted: Sun Jun 29, 2014 9:59 pm
No problem at all on SimonBBC and also another identical on a Accuspark. The Accuspark is for low ohm coil.
Both were running on old RVI Smiths Tachos.
The Simon BBC now runs an Accuspark Stealth Blackbox, also without any problems from the RVI Tacho.
PostPosted: Sun Jun 29, 2014 10:29 pm
I had an RV1 on Barney with a Pulsar electronic dizzy. It worked, but wasn't accurate. Worse on hot days. Could have been the old tacho- components ageing.
PostPosted: Sun Jun 29, 2014 10:44 pm
Good to hear. Eng has convertible minis elec ign mod and a gt40 coil.
PostPosted: Sun Jun 29, 2014 11:31 pm
PostPosted: Sun Jun 29, 2014 11:32 pm
PostPosted: Mon Jun 30, 2014 7:53 am
Try it, you won't hurt it... :wink:
Users browsing this forum: Andosoft and 92 guests
