It is currently Tue Jul 15, 2025 1:46 pm
PostPosted: Sat Aug 09, 2014 3:03 pm
Hi everyone I have pistons with letters and numbers on them. I have looked at 305 pages of previous chat and used the search over the past 2 days I have asked a mini parts supplier and a MG parts supplier the same question without any help both telling me to see an engine rebuilder all I want to know is how big of an oversize my pistons are .I do need to buy pistons and things but looks like I wont be buying from them . I have two sets of pistons in two motors one is a 76 998 and one is a pre 76 1100 from a morris 1100 sedan so im told and both have the same set of letters and numbers on them looking down on top of piston
they are lD6 T15 at the top and +1.016 and an arrow
they have 3 compression rings and two oil rings and seperater in bottom groove looks like 20397A is inside the skirt the pistons have clips holding the pin in
the piston measures 2.5665in 65.14mm and the hole they came from measures 2.5815in 65 57
the questions are what over size are they at and do we need to bore the block to the next size up
this would be greatly appreciated
ps don't know where this is going or how long it will take to come back new at this
PostPosted: Sat Aug 09, 2014 3:47 pm
in the How-To forum on this site you will find a Workshop Mini Manual. Its for a 67 but the 998 engine (and the 1100 block) is for all intents identical.
viewtopic.php?f=25&t=84427
So to identify the oversize, and therefore the next bore size. Your bore from your measurements is 2.5665, and from General Data page 12, the standard bore size is 2.543. Subtracting your measurement (being bigger) from the other gives 0.023 inches difference, that approximates a 20 "thou" of an inch overbore (More precisely, 23 thou). So the next bore you would consider would be 40 thou over bore.
The two pistons, although identical in bore sizes are not the same between a 998 and 1100 engine. The skirt on the 1100 is a little shorter to clear the longer throw crankshaft, so are different part numbers.
PostPosted: Sat Aug 09, 2014 3:51 pm
damn, I would've said different to that Mick, I reckon the existing pistons are 0.040" oversize.
standard bore for a 998/1098 is 64.58mm. Add 1.016mm to that and you get 65.596 which is 2.582"
PostPosted: Sat Aug 09, 2014 3:52 pm
I am working off the imperial measurement Simon, have I made a mistake just working with that? I don't like to swap back and forth imperial to metric.
Even working with the metric measurements I get 21 thou....
PostPosted: Sat Aug 09, 2014 3:55 pm
1.016 marking means they are +.040" oversize now.
This ties in with your approx bore measurement, the original bore 64.6mm and is now 65.57. near enough to 1mm = +.040" difference.
Bore sizes are the measurement, standard sizes these days are std, +.020, +.040, and +.060. You can go bigger...... :P
Pistons are smaller than the bore and are never measured at the top. They are much smaller there to allow for expansion.
Next oversize available to you is +.060" , will give 1152cc.
PostPosted: Sat Aug 09, 2014 3:56 pm
How did I stuff that up... :(
The maths from the measurements seem good, Is there two engines and two bores? A part number from one and a measurement from the other?
Thanks Doc and Simon..
PostPosted: Sat Aug 09, 2014 3:58 pm
I think it's more that you've gotta go off the bore measurement not the piston measurement - IE a .040" piston oversize fits into a .040" oversize hole with whatever clearance
rj's bore is spot on .040" and the piston has 1.016mm stamped on the top, which put two and two together for me
lol, 2 replies while typing...
PostPosted: Sat Aug 09, 2014 3:59 pm
so first correct answer gets a prize, right??
PostPosted: Sat Aug 09, 2014 4:03 pm
Ha. Thanks Simon. You get a sticker next time you drop in.
Other than that I'll crawl back into my box :)
Mick
PostPosted: Sat Aug 09, 2014 4:07 pm
Mick
it's usually me crawling back into my box after getting things painfully wrong... but at least when someone points out that I'm wrong they actually give the correct answer to the question instead of ignoring it. You posted your original reply while I was typing mine, which I then adjusted slightly ("damn") but very carefully checked my numbers :lol:
PostPosted: Sat Aug 09, 2014 4:10 pm
Peer review!
PostPosted: Sat Aug 09, 2014 4:20 pm
thanks guys
PostPosted: Sat Aug 09, 2014 4:21 pm
can I put a new set of flat tops in these bores ? just asking
PostPosted: Sat Aug 09, 2014 4:27 pm
Well you will probably find the bores are worn oval & tapered, , the usual practice is buy a set of oversize pistons, then get the engine shop to bore and hone to suit. Putting new pistons into old bores doesn't work.
Your choice to buy, flat or dished.
Price to bore & hone 4 cyls is $100-200 total, depending where you go.
PostPosted: Sat Aug 09, 2014 4:36 pm
ok cool thanks a lot im restoring someone else's nightmare so will end up with 76 clubby 1100 eng 295 head a cam with bigger lumps on it [sorry about the technical terms]on a set of 12in contessa's thanks again for your help
