It is currently Sun Jul 20, 2025 4:23 am
 Post subject: Dash crash pads
PostPosted: Wed May 18, 2005 12:35 pm
Clubmans have a black vinyl crash pad across the top & bottom of the dash. Is it possible to remove these and fit them to a round nose shell?
PostPosted: Wed May 18, 2005 12:36 pm
I think so. Just a couple of screws under the vinyl.
Well, I hope so, I want to do the same thing.
PostPosted: Wed May 18, 2005 12:37 pm
Yep.
Top one has 3 or 4 studs in it, that pass through the metal rail. You might nees to drill holes for these studs.
Bottom one is glued on, then held with some trim clips on the back top edge.
Easy peasy :wink:
PostPosted: Wed May 18, 2005 12:50 pm
easy peasy. Dont get too enthusiastic and wreck your bottom one when you take it off.
Slow and steady wins the race! I got a little "enthusiastic and ripped it in half!! :oops:
Lucky i have a replacement!
PostPosted: Wed May 18, 2005 12:54 pm
J_A_M wrote:
Yep.
Easy peasy :wink:
I remember the studs in the top one. Makes that easy.
The bottom one that's glued on, do you think some heat would help soften the glue maybe?
PostPosted: Wed May 18, 2005 12:57 pm
depends when it was stuck on I spose..... mine almost fell off.
PostPosted: Wed May 18, 2005 1:08 pm
Maybe someone at BMC was nursing a hangover the day yours came down the assembly line :lol:
Thanks for the input :wink:
PostPosted: Wed May 18, 2005 1:11 pm
or injured their hand on the way to work after tripping and falling over a door mat
:shock:
PostPosted: Wed May 18, 2005 6:24 pm
"dash crash pads"
are they really pads for when you crash? some sort of protection?
Inconspicuously Conspicuous
Users browsing this forum: No registered users and 68 guests
