It is currently Wed Jul 16, 2025 3:58 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2, 3  Next
PostPosted: Sat Oct 11, 2014 1:27 pm
I plan to fully rebuild a 4 sycro remote box. This box is for my 1360 BMW twincam build, it'll have a Quafie ATB diff with a 3.1 FD and the engine will be tuned for torque. So with all that in mind.
I'll have a heap of questions but for now I'll only ask five. Currently I have striped as much out as I can and I need some guidance with a few things.
(1) The drain has striped out so what are my options :?:
(2) How do I and is it nessary to remove the speedo drive :?:
(3) Should I replace the driveshaft output bushes (the bearing thingy) :?:
(4) The top and bottom bushes in the diff housing for the gear selector shaft, the shaft seems to move around a bit in them. How tight/loose is the shaft meant to be, should I replace these :?:
(5) cleaning up the threads on everything, what taps and dies do I need :?: And I'm assuming I leave all the studs in where they are correct?
 Post subject: Re: Gearbox rebuild
PostPosted: Sat Oct 11, 2014 6:43 pm
You can get plugs for stripped drain threads here, but you will probably be better off with a helicoil. I have never used a helicoil, but i have one on my gearbox in the same place, and it works well.
It should slide out from the side once you have removed the cover plate. You shouldn't need to touch it though.
Only if they're worn, I'd say. I've never seen them wear down before, but they may well do.
They shouldn't be tight, but they should move freely with little sideways movement. I'm not sure what you would do to fix that.
Can't say off the top of my head - I'm not good with thread sizes anyway.
PostPosted: Sun Oct 12, 2014 12:31 pm
For the drain plug I helicoiled it - have some left over if you need it.
David L
PostPosted: Sun Oct 12, 2014 12:34 pm
You can take the studs out, it makes cleaning the gasket surfaces easier. Its just time consuming.
You will need 1/4 and 5/16th and a 3/8 UNC finishing taps to bottom out the threads.
The studs will have UNC on one end, and UNF on the other.
PostPosted: Sun Oct 12, 2014 6:10 pm
The 2 side cover bushes are usually worn- press new ones in then get them set up true in a lathe and machined to size for ~.001" clearance on your drive flanges or pot joints. If you leave them worn the seals won't last long before leaking.
These bushes are about .007" undersize when bought.
The 2 shift shaft bushes in the diff cover wear bad and should be replaced. I screw a 9/16" UNF tap in, then use a hammer and a bit of 3/8 rod to drive them out. You could also use a 14mm tap.
PostPosted: Sun Oct 12, 2014 7:29 pm
4/ you can just catch the side of them with a long drift, or use a slide bearing puller. Easy job
PostPosted: Sun Oct 12, 2014 8:28 pm
Thanks for the answers so far.
Can I use selector shafts and knuckle joint parts from a 3 sycro remote box? It's only the gear clusters that are different correct :?: Can you fit 4 sycro gears into a 3 sycro box, what is the difference between the two boxes :?:
PostPosted: Mon Oct 13, 2014 6:45 am
The knuckles and shift shafts they attach to are the same.
The selector shafts in the bottom of the box are not.
The 4 synchro case is wider inside, and machined differently. Can't fit 4 synchro setup to a 3 synchro case. Go find a Mink K/1098 Clubby box..
PostPosted: Mon Oct 13, 2014 5:58 pm
Thanks Doc, also (I can never remember) can the gears out of a rod change be installed in a remote box :?: (I think the answer is yes but I want to confirm for sure).
PostPosted: Mon Oct 13, 2014 6:14 pm
4 syncro gears are 4 syncro gears, doesn't matter what shift type
PostPosted: Mon Oct 13, 2014 7:29 pm
Except reverse idle gear, thats different. NLA I believe
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Mon Oct 13, 2014 8:00 pm
Might be NLA new, but PM me if ya need a good s/h one.
The difference in the reverse gear is the groove position for the selector fork.
PostPosted: Sun Nov 02, 2014 6:43 pm
I have just rebuilt a box now it's stuck in either 1st or 2nd? I can still select 3 , 4 and R ..... What have I done ?
PostPosted: Sun Nov 02, 2014 7:27 pm
Did you line up all the bell crank levers putting the selector shaft in?
5/72 Clubman Gt
PostPosted: Sun Nov 02, 2014 7:32 pm
Yeah I think so. I just had to replace 1st gear so I left all the selectors in.
