It is currently Sun Jul 20, 2025 10:22 am
PostPosted: Sun Nov 02, 2014 10:06 pm
I did a oil change today on race car, found some bits that shouldn't have be on the end of the sump plug, I need some help determining were they came from, I am thinking needle roller cage ??? drop gears ?? :?: :?:
All the pieces are the same length and width :cry:
PostPosted: Sun Nov 02, 2014 11:38 pm
Im thinking gbox input bearing cage.
Not good tho. Looks like your in for an engine removal shortly
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Mon Nov 03, 2014 10:29 pm
Could it be the ring that goes on the outside of the main double row bearing?
PostPosted: Tue Nov 04, 2014 10:22 am
Damn shame Mal.
Want a go in mine?
PostPosted: Tue Nov 04, 2014 11:25 am
let see if you can get it around the track without breaking it first :roll:
Mal
PostPosted: Tue Feb 17, 2015 7:57 pm
Well I have finally had time to pull the race engine, the inboard drop gear bearing was the culprit, luckily no damage to idler gear shaft or casing. I have brought new swiftune roller bearing drop gear set, that should stop it happening again.
Are their any tips for stopping this happening to my spare race motor in the future ?? or is it a case of always use good quality bearings ?
PostPosted: Tue Feb 17, 2015 8:26 pm
it appears as though you already know the correct answer.
It's easy once you know how.
PostPosted: Tue Feb 17, 2015 8:36 pm
Yes, I'd Say I have, but what did do back in the day before some smart bugger came up with roller bearing type ??
PostPosted: Tue Feb 17, 2015 8:50 pm
straight cuts to reduce the twisting loads on them?
PostPosted: Tue Feb 17, 2015 9:20 pm
These days, not all bearings are made to the same spec.
For example, it is well known that the Chinese are selling their imitation Branded (SKF, Timken etc, take your pic) bearings around the world through some parts retailers (not genuine bearing distributors). Even their packaging looks pretty legit.
These idler gear bearings are a stock Imperial size; well known brands eg Torrington are still available through bearing shops.
Or, ask where your supplier gets his from. :wink:
[edit] I have to say, I have never had a problem with a bearing collapsing. I buy them here from the usual Mini shops, unless they are all out of stock.
Last edited by drmini in aust on Wed Feb 18, 2015 5:28 pm, edited 1 time in total.
PostPosted: Tue Feb 17, 2015 9:48 pm
Mental note to self, don't buy gearbox rebuild kits from minisport uk, they may be cheap but they supply crap bearings.
PostPosted: Wed Feb 18, 2015 7:07 am
I think it would be tough for any supplier to spot the shoddy bearings from the good all the time. These brands were once the best in the game.
PostPosted: Wed Feb 18, 2015 3:29 pm
on a better note
the swiftune bearing set up looks quite neat - but a pity it doesn't mix and match with existing straight cut drop parts -
Users browsing this forum: Scoop and 80 guests
