It is currently Sat Jul 19, 2025 9:44 pm
PostPosted: Sat Nov 15, 2014 8:58 pm
What is the difference between the standard and Cooper S diff side plate?
I know the ID is larger on the S,
But is the OD for the seal the same or also larger?
Can you modify a standard side plate to fit the S?
(S being Hardy Splicer Joints)
Thanks in advance.
PostPosted: Sat Nov 15, 2014 9:32 pm
I thinks the o/d of the seal is slightly large. 47.3mm o/d normal and 50mm o/d for the S type.
Thats what I found looking on the web anyway.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sat Nov 15, 2014 9:50 pm
some later Moke side plates can be modded (bored) but I just use Morris 1500 side covers with a minor mod (skim).
PostPosted: Sat Nov 15, 2014 11:03 pm
The S seal is 1/8" bigger on OD and ID. So is the bronze bush, and it's 5 times dearer than a Mini one.
So you have to bore the cover for both. And then fit & bore the bush, as they are supplied ~.007" undersize.
The side covers to bore out are the ones with a machined ring on the outer corner, where a shroud was fitted. I think Mini K and early Clubby had these, as well as the Mokes. They have no part number on them...
These covers have more meat around the bush than the early ones.
Users browsing this forum: 748rum, rhaj and 82 guests
