It is currently Fri Jul 11, 2025 10:18 pm
 Post subject: Indecator earth point
PostPosted: Mon Dec 08, 2014 5:48 pm
Hi guys
My rear left indecator is not as bright as the right side. Annoying
Anyone know where the R/L indecator is earthed?
Black is the new Black
PostPosted: Mon Dec 08, 2014 5:55 pm
They share a common earth behind the fuel tank, so if one is working, then it has the same earth point as the other.
I would recommend you swap bulbs from left to right to make sure its not simply the fault of the bulb. It may also be the front bulb affecting the rear, check for intensity at the front and if all that doesn't cure it, check the connections green/red and green/white at the indicator arm as well. Swap them to see if the problem follows.
One last spot is the three-way connection behind the instruments ,and the front/rear connection plug behind the wiper motor.
PostPosted: Mon Dec 08, 2014 9:43 pm
Thx Mick, did the bulb swap, no change. I will check the connections you mentioned tomorrow.
Rob M
PostPosted: Tue Dec 09, 2014 8:05 pm
Also check the wiring connections at the back of the indicator assy's where they attach to the loom, they could be dirty and need a cleanup too!
Cheers Shane
Users browsing this forum: Bing [Bot] and 122 guests
