It is currently Mon Jul 14, 2025 2:04 pm
PostPosted: Wed Dec 10, 2014 12:57 pm
Afternoon Gents,
Currently on the mini market to buy another one. Had one back in 2005 and loved it but as a student ended up having to sell. So i have been looking for another one and ive found one im interested in.
My dilemma is its registered in qld and i want to bring it back to nsw. Its a 1275 engine and only has oversized drum brakes on the front.
Ive searched through ausmini and people say it needs disc brakes to be registered then some people say when getting a blue slip the brakes never got checked and some have even passed with drum brakes. Does anyone know if there is a official rule on this?
Also if i do need to change them, can i buy it and run it on qld rego (which runs out end of march) and change it to disc brakes in between now and then, then blue slip it in nsw and rego it?
Thanks in advanced!
PostPosted: Wed Dec 10, 2014 1:43 pm
The official rule is that all 1275 minis came with discs - so discs are required. Some people may have had them registered without, but that's probably because the people doing the rego didn't know. Only exception to this rule that I know of was some of the 1275 mokes had drum brakes.
Edit: Yes, drum brakes on the mokes, not discs.
PostPosted: Wed Dec 10, 2014 1:51 pm
Shouldn't that be one model moke had a 1275 and drum brakes
PostPosted: Wed Dec 10, 2014 2:05 pm
I wouldn't buy a Mini with a 1275 and drums and not expect to need to change them to get it registered. If the car plus a disc brake kit fits in your budget then go for it.
PostPosted: Wed Dec 10, 2014 2:47 pm
What is a budget? Lol
Ill just have to be a tight ass this xmas... Sorry nieces and nephews
PostPosted: Wed Dec 10, 2014 3:18 pm
In answer to your question on running it on QLD rego. If you are resident in NSW (or move here from interstate), you have a defined amount of time before you need to change over your license (if applicable) and registration. That info should be on the RMS website. It might be three months I think in the case of registration, in which case you may well squeeze it in with some good planning.
Would the owner be willing to allow you (without them transferring it/submitting disposal notice with QLD Roads in the meantime) would be the question.
AND - what would you do with insurance?
Plausible, but probably BUSTED to quote the Mythbusters
PostPosted: Wed Dec 10, 2014 5:52 pm
I got a cousin that lives in qld. Was just going to transfer rego in their name and then bring it to syd, get the discs put in and blue slip before rego runs out
PostPosted: Wed Dec 10, 2014 10:18 pm
Blue slip is essentially identity check, should look at standard safety items as well, as done for pink slip.
The rules are available from the source http://www.rms.nsw.gov.au/roads/registration/index.html
look at the section "Authorised Unregistered Vehicle Inspection for light vehicles"
and the section "Modified and non-standard vehicles – VSCCS"
http://www.rms.nsw.gov.au/roads/registration/get-nsw-registration/modified-nonstandard.html
the section "Owner-certified modifications"
RMS wrote:
Modifications which add optional equipment to a vehicle can generally be owner-certified.
Non-standard modifications of a minor nature which do not affect the level of safety, strength or reliability of vital systems like brakes and steering, may also be owner-certified.
These modifications have little or no impact on the vehicle’s level of compliance with the Australian Design Rules.
The vehicle must still pass an identity and eSafety Check at an Authorised Unregistered Vehicle Inspection Station (AUVIS).
The modification of the car you are contemplating is the fitment of an engine that was factory optional in certain models of the car. In order to owner certify, all other equipment that came with that factory fitted engine option that affect safety must be fitted. In other words the brakes must be discs.
If you have any doubts then call the technical number the RMS gives you.
RMS wrote:
ore information
General enquiries
For general information about the VSCCS, phone 1300 336 206 or email [email protected].
Technical-related enquiries
For technical information in relation to a vehicle, contact Technical Enquiries by phoning 1300 137 302 or emailing [email protected].
Standards-related enquiries
For information on standards, contact Vehicle Standards & Compliance by phoning 1300 302 402 or emailing [email protected].
If you do not fit the disc brakes, i guarantee you that your insurance will not be valid and you will be liable for anything that happens. Not worth the risk.
michael
