It is currently Fri Jul 18, 2025 3:29 pm
Post new topic Reply to topic  [ 151 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 11  Next
 Post subject: Re: Project 68mm
PostPosted: Thu Dec 11, 2014 5:53 pm
mini_mad_matt wrote:
He did, years ago
https://www.youtube.com/watch?v=H70vEq_FMvs
PostPosted: Fri Dec 12, 2014 6:22 pm
Mind is going on me. Forgot the smallbore one that Matty did.
PS. that youtube is the 1360cc
PostPosted: Fri Dec 12, 2014 6:37 pm
Yeah Matt's a bit lazy when it comes to showing off what he builds :roll: :lol: :lol:
PostPosted: Sat Dec 13, 2014 11:59 am
Great work on the 1220 Graham. :)
If this idea really takes off, we might need some new 1098 cranks.. they are all old and many have worn out or broken now.
How about some nice 8 counterweight billet ones like your 1275 race cranks? Or just Oz made billet 1098 copies? Could be done?
PostPosted: Mon Dec 15, 2014 1:26 pm
Oh dear, worry, worry...
Hi All,
Here are some more photos that should have gone up before, showing more detail.
Aaron's Fault.
We have done more some more testing with a modified inlet port and an 1 3/4" SU. The results were very good.
These will all go up on the website, when Aaron gets his act together and types it all up....
Graham Russell :D
PostPosted: Mon Dec 15, 2014 1:28 pm
KMX still good?
PostPosted: Mon Dec 15, 2014 3:05 pm
Love the throttle cable
PostPosted: Mon Dec 15, 2014 4:10 pm
Does it sit well in the engine bay? Any clearance problems for an airfilter?
PostPosted: Mon Dec 15, 2014 6:48 pm
Can this also be done on a 998?
PostPosted: Mon Dec 15, 2014 7:14 pm
http://russellengineering.com.au/july-2014-update/
Nick
PostPosted: Mon Dec 15, 2014 8:08 pm
Hi Mick
You have about 35mm clearance it seems to vary from car to car you can buy air cleaners that are about 25mm thick,but then again you could make a big flat one, and I think it's finer filter will make the foam to fit.
Graham Russell
PostPosted: Mon Dec 15, 2014 8:21 pm
Hi Kennomini
Yes it can be all done to 998 with these 68mm pistons you will have to take .140 off the top of the block which is not a problem, you can if you want re drill the head studs holes a little deeper there is plenty of metal on the top of these blocks to do so, this takes the 998 out to 1107cc which makes it a little screamer, I am building one of these as well just give me a little time, and with the right cam and head 9000rpm will not be a problem. 8)
Graham Russell
PostPosted: Mon Dec 15, 2014 9:41 pm
GR wrote:
Hi Kennomini
I am building one of these as well just give me a little time, and with the right cam and head 9000rpm will not be a problem . 8)
Graham Russell
Would that be street or race engine? Street would be crazy fun :P .
PostPosted: Tue Dec 16, 2014 8:01 am
Kennomini wrote:
GR wrote:
Hi Kennomini
Graham Russell
Seconded
Nick
PostPosted: Sat Jan 10, 2015 8:57 pm
Ok, Ok, I got it done.
More soon.....
www.russellengineering.com.au
