It is currently Tue Aug 05, 2025 10:05 am
PostPosted: Thu Jan 01, 2015 1:12 pm
is something more sinister going on?
In the last 5 running hours I've had in order; coil fail, plug failure (ngk), condenser failure (amazing backfires) followed by another plug failure, different cylinder (denso)! Whats going on! Thoughts please!
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Thu Jan 01, 2015 3:13 pm
Rover Cooper
your not 3 feet under water are you, :-[, good luck with your faults, someone on here will stear you in the right direction.
PostPosted: Fri Jan 02, 2015 8:31 am
No No , nothing wrong with it , normal mini behavior :lol: .
Is it ok now , prior to that , was it running ok , had you changed anything in the tuning dept , how long since it has played up , could be just a coincidence that all this just happened to die .
PostPosted: Fri Jan 02, 2015 11:23 am
now my tablet is playing up Arrrgh! When the car is actually running, very smooth and responsive. Torquey and heaps of go. Ive done nothing to it except replace broken electrical stuff. Dont think its heat related...
67 Deluxe
Dry suspension
PostPosted: Fri Jan 02, 2015 2:14 pm
EMP from the nuclear bomb.
Seriously, It may have been that everything was on its way out and as soon as you replace one thing the next worse thing becomes the problem.
PostPosted: Sat Jan 03, 2015 7:57 pm
So am I just having a bad run? Alternator is putting out correct voltage and the coil and plugs were newish (12 months or so, Denso plug a month old)....
67 Deluxe
Dry suspension
PostPosted: Sun Jan 04, 2015 7:09 am
I suggest you just change everything and start again...a shorting condenser may have taken out your coil, but really, just move on...the quality of replacement parts can not be guaranteed these days.
PostPosted: Sun Jan 04, 2015 7:51 am
How can a condenser damage a coil? When a condenser fails the coil does not function properly buy Condenser does not damage coil.
"Let us remove your "SHORTS"
PostPosted: Sun Jan 04, 2015 8:41 am
This is a British designed car, you should never discount even the the weirdest things. :lol:
IMO its just normal old car scenario, don't loose any sleep over it.
PostPosted: Sun Jan 04, 2015 9:21 am
It is probably more a case of keep replacing perfectly good parts till you stumble upon the real problem.
PostPosted: Sun Jan 04, 2015 1:08 pm
"It is probably more a case of keep replacing perfectly good parts till you stumble upon the real problem".
That is easier said than done till in the process you introduce something else that is faulty which complicates things further. It is always best to test and find what is faulty before you take guesses and replace bits.
PostPosted: Sun Jan 04, 2015 1:38 pm
Electronic points = no condensor or points ever again, no dwell setting's either... I'll never go back!
If you set your dwell incorrectly, it is possible to over heat the coil which will degrade the coil over time, and perhaps the points as well from increased heating through longer charge cycles...they barely support a normal coil as it is without 6 monthly adjustments. A poor spark leads to improper ignition which will soot the plugs too...but maybe you were just unlucky. A clean sweep of the electricals is not a bad thing every once in a while.
PostPosted: Mon Jan 05, 2015 2:21 am
Thanks for all your input. Mick, I think the dwell is fine because the machine is running sweetly and smoothly when there is nothing failing! (points are good). Will keep you posted.
Mikal
67 Deluxe
Dry suspension
