Irish Yobbo wrote:
It sounds to me like you're going about the wrong way to solve the problem. Yes, you can keep the battery charged, but an immobilizer shouldn't discharge the battery so quickly. My old one would last about two weeks before the battery started showing signs of a struggle - but it turned out to be the alternator anyway. I've since changed alternators (to one of ConvertableMini's upgraded ones) and changed to anew alarm and immobilizer. I went on holiday for almost 6 weeks with the alarm/immobilizer activated, and it still started up fine.
What I would suggest is seeing how much current is draining from the battery with an accurate multimeter. Then unplug the alternator and check the difference. If it is the immobiliser that's draining, get a new one. If you're happy to do the install yourself, they're very cheap.
I have a similar problem, the Pioneer Radio/CD head unit eventually drains the 640CCA battery.
Any head unit should have a permanent +12V connection and an accessories connection. The accessories connection effectively acts as a relay - if there's no accessories connection, your head unit should only drain the smallest amount of power (only to keep time and radio presets etc - a AA battery would have enough power to do this). No head unit should drain a battery unless it's old/cheap and given a long amount of time (several weeks).
Well I suspected the alternator, but I cannot measure any mA drain from it with the engine off.
Yes the ign switch has an accessories position, all that does is let the radio work without ignition on.
IMO it's the permanent 12V+ connection that keeps its memory alight that's the problem.
I could turn the battery isolation switch off, but then I have to re-program the !^&%$* head unit each time. PITA...
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
