It is currently Sun Jul 20, 2025 12:48 pm
PostPosted: Thu Feb 19, 2015 8:59 am
Replacing front cones in Laingy's van... getting the old corroded *&^$( trumpets out of the rubber cones is a pita.
After trying all the common methods of removal yesterday with no joy, we finally hooked up my Supercrap air chisel.
Rat-a-tat-tat, instant success. 8)
Thought it worth sharing. :wink:
PostPosted: Thu Feb 19, 2015 9:03 am
that`s what we`ve been doin for years :-)
PostPosted: Thu Feb 19, 2015 9:37 am
Online
Hold the trumpet by the ball joint end and whack rubber cone sideways against old tree stump. If necessary, rotate 90deg and whack again. Continue as necessary
That way you don't damage anything - just in case the cone is salvageable.
Cheers, Ian
PostPosted: Thu Feb 19, 2015 10:10 am
Cheers, Ian
That's fine, if out of the car... but these were still in. :lol:
Both cones on this car look like donuts, it was sitting on the bumpstops.
Had to turn the cones 90deg to horizontal, to get them out.
[edit] typo
Last edited by drmini in aust on Thu Feb 19, 2015 12:59 pm, edited 1 time in total.
PostPosted: Thu Feb 19, 2015 12:55 pm
I had to use a fencers crowbar and belt it with a sledge hammer
PostPosted: Thu Feb 19, 2015 1:35 pm
I put the aluminium cone in a bench mounted vice and hit the rubber cone with a 2.2kg sledge hammer. Worked well for me!
PostPosted: Thu Feb 19, 2015 5:57 pm
They can be a s#it to get out of the subframe when they all squished and old. I use my 500mm long snsp on prybar to force them out and air chisel once on the bench...
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
Users browsing this forum: 1071 S, Bing [Bot] and 73 guests
