It is currently Sat Jul 26, 2025 10:21 pm
PostPosted: Fri May 20, 2005 8:10 am
yep, 2,500 - 3000k here, it actually needs doing now but since it's unregistered atm I've been putting it off :lol:
PostPosted: Fri May 20, 2005 8:17 am
Mike wrote:
Hey can we just confirm again - somebody was saying that the $8 per 4 litres Kmart Price Brand oil is just the 20-50 Mobil oil and is great for the mini - it that true?
Anyone used them>?
Graham Russell uses it for running in engines. I think it's packaged by Shell.
I'm using Valvoline SF 20W/50, $9.95 for 4 litres, at AutoOne. Not bad for a brand name oil, and it holds pressure well even when hot after a freeway run..
PostPosted: Fri May 20, 2005 8:24 pm
I change my oil every 2500 miles. I was doing it every 3000 but the oil was getting too thin towards the end.
Don't forget to grease the suspension at the same time.
 Post subject: black
PostPosted: Fri May 20, 2005 8:36 pm
I change oil by how it looks, length of time its been in, long trips done, how black it is or how easily it drips off the end of the dipstick.
Oil is a cheap mechanic...
cold starting...dilution with condensed water and unburnt fuel just lessen its effectiveness.....
why leave it in :?: just to boast how long you get between changes.. :?:
PostPosted: Sat May 21, 2005 1:38 pm
Speaking of greasing the suspension - I need to buy a grease gun - what size nipples are on a mini - do I even have a choice - ie are they all standard sizes?
PostPosted: Sat May 21, 2005 2:09 pm
All the same. Standard fitting.
Make sure the gun takes a grease cartridge- too damn messy otherwise. :lol:
 Post subject: Oil and Grease
PostPosted: Sat May 21, 2005 7:54 pm
I top up with oil every monday, by the burn rate I figure it self changes every 1000 miles hehe. Think it's coming down the valve stem with high vacume take off. Anyway I really recommend a good grease of all points as it turned my 78 boxman into something I would be happy to call a mini.
Users browsing this forum: drmini in aust and 96 guests
