It is currently Fri Jul 18, 2025 2:59 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Feb 28, 2015 10:32 am
PS: we already have a couple of 6-speed dog boxes that (after some time & effort) are proving to be quite bullet-proof
but the automatic gear-case seemed a far better platform/base to me for the 20v project.
PostPosted: Sat Feb 28, 2015 10:42 am
i had previously looked at cutting one of these down the guts (in half) to make a 2.2litre alloy motor
P76 Alloy 4.4L ,,, this one in the process of being coupled to a VW gearbox for an open wheeler (Yes with the turbo) :-)
But i only have 12x of them & really didn`t see the need to waste one :-)
PostPosted: Sat Feb 28, 2015 10:45 am
Could you practice on a rover 3.5 or are the internal galleries too different?
PostPosted: Sat Feb 28, 2015 4:45 pm
i have 3x Rover V8`s ,,,they`re not the same , but similar,,, just a shorter block, shorter stroke crank & slight differences elsewhere, like flywheel/crank bolt pattern etc
much the same & yes a bit smaller & lighter
we can make a 5Litre engine from them pretty easy
but we can make a 6litre engine from a P76
so that tells me (if i were really nuts),,, that i could make a small lightweight V4,,, or in-line 4 with 3litre capacity & shove that into a brick,,, if i were really nuts & really rich :-)
I suppose i`m half way there hey? :-)
PostPosted: Sun Mar 01, 2015 10:03 am
I'll give you a couple of grand for an alloy V4 engine :P . Can I pick it up next month......?
PostPosted: Sun Mar 01, 2015 4:00 pm
i have a decent 9" angle grinder :-)
