It is currently Sun Jul 20, 2025 3:58 pm
PostPosted: Tue Mar 10, 2015 1:40 pm
So I found a thread on the Mini Forum posted by "Gearbox Guru" which states.......
Loose the lock tabs which previously held the bearing retainer in place.
Clean the bolts for the bearing retainer and install using ThreadLock
Tighten and torque to 15lbft
Has anyone done this? Seeking a second opinion please.
I guess the bolt hole also has to be clean (no oil) so that the threadlock holds.
The referred 'bearing retainer' is the one holding in the lay-shaft retainer.
The top lock tab has a locator tang, and one bolt.
The lower one is located between both bolts.
PostPosted: Tue Mar 10, 2015 1:53 pm
Later cars with rodchange box had spring washers & no locktabs I think.
I always use spring washers + Loctite 262 on the threads.
PostPosted: Tue Mar 10, 2015 2:14 pm
"Gearbox Guru" is John from http://www.guess-works.com/ who would be up to speed with the latest build up trends!
Cheers Shane
PostPosted: Tue Mar 10, 2015 2:36 pm
Thanks Doc.
Is there anything special about the 262 variant?
PostPosted: Tue Mar 10, 2015 3:18 pm
Cheers Shane
Thanks for the link Shane, great :)
PostPosted: Tue Mar 10, 2015 3:36 pm
MiniBob wrote:
Thanks Doc.
It's called super studlock. Holds well but can be undone without heat.
Loctite 242 would be good enough.
PostPosted: Tue Mar 10, 2015 3:55 pm
Thanks again. Repco on the way home :)
Users browsing this forum: fuzzy-hair-man and 68 guests
