It is currently Sun Jul 20, 2025 3:43 pm
PostPosted: Sun Apr 12, 2015 11:54 am
Hi all, does anyone know where I could get centre caps for Contessa"s?
Something like pictured. Image
PostPosted: Sun Apr 12, 2015 2:30 pm
Mine have 62mm holes, so something like this might fit. (It's also the same size as the lids on aerosol cans)
http://pages.ebay.com/link/?nav=item.vi ... 1669508070
The wheel repair shop near me had bunches of them to choose from
PostPosted: Sun Apr 12, 2015 6:47 pm
I had a metal spinner make a set of caps to the exact size. Then I had these chrome plated. It's a bit fussy, but the results were excellent.
PostPosted: Sun Apr 12, 2015 7:20 pm
Might have too look into making some custom caps.
PostPosted: Sun Apr 12, 2015 9:03 pm
Ab has a set
[url]http://instagram.com/p/eWCJqvFmLf/
[/url]
PostPosted: Mon Apr 13, 2015 12:34 pm
styrofoam cups work :D
PostPosted: Mon Apr 13, 2015 12:36 pm
Might whittle a set out of a tree trunk. :)
PostPosted: Mon Apr 13, 2015 1:05 pm
Here are some more:
http://www.minispares.com/product/Class ... ACAPS.aspx
I might actually buy a set of these, just need to check a few measurements first
http://www.ebay.com.au/itm/CENTRE-CAPS- ... 19fe308921
PostPosted: Mon Apr 13, 2015 1:21 pm
timmy201 wrote:
Here are some more:
Mine measure 63mm, those minispares ones might work. The other chrome ones might be too tall for a Mini, unless you cut them down.
Thanks for all the replies!!
PostPosted: Mon Apr 13, 2015 1:31 pm
Here's some I prepared earlier for a mate's S- machined from black HDPE. I'm not doing any more, but feel free to pinch the design. :lol:
PostPosted: Wed Aug 19, 2015 6:48 pm
I found some caps at the wreckers today. Bit of a gamble as I didn't have anything to measure them at the time, but worth a go at $10 for a set of 7..
They ended up fitting quite nicely, they stick out about the same amount as the wheel nuts. Just need to peel off the logos and give them a quick polish!
PostPosted: Wed Aug 19, 2015 11:01 pm
I talked to John @ Minikingdom on Monday about sourcing some; he said he's in the process of looking at having some made up. Not sure of time span involved though.
Those ford ones look the job; great find.
Eiles
PostPosted: Thu Aug 20, 2015 8:07 am
I;ve got some tall black caps here
PostPosted: Thu Aug 20, 2015 8:58 am
Don't forget to measure the hole first ... not all Contestas have the same size center holes..
Cheers, Ian
PostPosted: Thu Aug 20, 2015 12:21 pm
Rover Cooper
a can of coke cut in half, fits just nice, and their easily replaced. Even VB fit to, much better to empty than Coke.
