It is currently Sun Jul 20, 2025 6:58 pm
PostPosted: Mon Apr 13, 2015 6:47 pm
:roll:
I think I already know what the problem is but I would like some opinions from the 'knowledgeable'
Symptoms - running very rough, needs choke to start, no power (only up a gentle hill if in first), will not respond to throttle, slowly builds up revs after a 5-10 second delay, plugs on 1 and 4 look good but 2 is 'sooty' and 3 is black and slightly moist.
I haven't done a compression test yet (I need a gauge) and when I rebuilt the HS4 yesterday apart from being badly 'bodged' when last assembled it also had a fair bit of black (carbon??) in the throat on the engine side of the butterfly.
So what do we think? :shock:
"Never attribute to malice that which can be adequately explained by stupidity!"
1972 Mini Clubman 1098
1978 Leyland Mini 998 - she’s gone to a good home
PostPosted: Mon Apr 13, 2015 6:56 pm
head gasket
PostPosted: Mon Apr 13, 2015 8:19 pm
Rocker clearances too tight?
PostPosted: Mon Apr 13, 2015 8:44 pm
condensor
PostPosted: Mon Apr 13, 2015 9:07 pm
Timing way out.... backfiring?
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Mon Apr 13, 2015 9:45 pm
Vacuum pipe to dissy fall off?
Sucking air?
PostPosted: Mon Apr 13, 2015 10:08 pm
Points closed up?
PostPosted: Mon Apr 13, 2015 10:51 pm
Whoa....that's a broad range....and he's me thinking burnt exhaust valves :oops:
In addition I should have mentioned that it is running what look to be almost new NGK BP5ES plugs, the vacuum advance on the carby is blanked and also removed from the dizzy. It only backfires on decel. This Mini is new to me and has been sitting with almost no use for about 6 months at least. I have almost no history of the mechanics of the car because the young fella I bought it from had no mechanical back ground and didn't ask.
I also suspect the fuel may be contaminated so that's coming out next and the tank and lines cleaned....and then that compression test.
Oh and thanks for all the suggestions thus far
PostPosted: Mon Apr 13, 2015 11:33 pm
Bad fuel will give you all your symtoms..
Minis..
1975 van
PostPosted: Tue Apr 14, 2015 6:57 am
Its probably the battery Son
1962 Mini Speed sports sedan
PostPosted: Tue Apr 14, 2015 8:27 am
Where's that Dad?
PostPosted: Tue Apr 14, 2015 9:31 am
In the boot son.
I know the exact problem, there's something wrong with the motor thingo under the front cover bit.
Seriously though Id start with comp test before jumping to any conclusions, it might be something else but given your description it sounds like surgery.
PostPosted: Tue Apr 14, 2015 12:40 pm
R the plug leads on right
PostPosted: Tue Apr 14, 2015 3:42 pm
It helps if you put your location in , there maybe someone close by that could lend you a compression gauge.
PostPosted: Tue Apr 14, 2015 6:10 pm
Bloody hell....nobody's called me 'son' in the last decade :shock:
I'll update my details but for what it's worth I'm in Albany (West Oz)
My thoughts were 'surgery' too....but I'll go through the basics first (firing order, ignition parts, dizzy which looks really rough, compression test, etc)
We'll get there in the end :D
Users browsing this forum: Steam and 70 guests
