It is currently Mon Jul 21, 2025 1:31 am
PostPosted: Tue Apr 14, 2015 6:16 pm
Hi guys, i need to know a fairly simple question.
Does the centre point between the two drivers seat mounts (on the floor crossmember) Line up with the steering column?
Do those of you who run non-standard seats use the same mounting points on the crossmember?
Thanks in advance
1963 850 - laid up
PostPosted: Tue Apr 14, 2015 6:29 pm
The answer according to my car is no. The steering is definitely offset to the left of the seat
You can just see the seat mounts at the bottom of the photo and the steering column at the top. The steering column lines up almost with the adjustment lever on the left
PostPosted: Tue Apr 14, 2015 6:49 pm
Wouldn't the seat mounting bolt holes give you the right location?
It might alter depending on the seats you put in though. Perhaps you need to select the seats you will use and go from there.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Tue Apr 14, 2015 6:51 pm
I can give some measurements taken from the inner sill using a tape measure and a plumb bob...
Centre of the steering wheel = 350mm from the inner sill.
The column is offset to the seat, I will just duck out and take some in relation to the seat mounts...
PostPosted: Tue Apr 14, 2015 7:02 pm
Thanks guys.
See i need it for my rollcage. They want to know the seating position so they can place the harness eyelets directly behind the seats.
I have heard the steering column lines up with the centre of the seats and then others saying it doesnt (thanks to you guys its confirmed it doesnt line up), then with non-standard seats it looks like some people run their seats offset from normal to line up with the steering wheel.
I havent bought any seats yet, and hadn't thought of them until the question was asked yesterday. I dont even know where people go to try/buy car seats, not the foggiest!
So i am unsure what measurement to give AGI. If everyone just runs their seats in the standard position then thats great, but, if its a well known idea to run seats with rollcages and harnesses more inwards/inline with the steering then i'd give them the steering centreline.
In short, Damn minis and their lack of width!!
1963 850 - laid up
PostPosted: Tue Apr 14, 2015 7:10 pm
This shows how far from the centre of the column the right seat mount is...
This is the left seat mount...
PostPosted: Tue Apr 14, 2015 7:44 pm
Thats awesome Morris1100!
Thanks for that. So much easier if you have a bodyshell!
So the steering column is 80mm closer to the left seat mount....
I really appreciate your efforts guys. Thank you very much
1963 850 - laid up
PostPosted: Tue Apr 14, 2015 7:49 pm
Are you working on the Cooper S Mick?
PostPosted: Tue Apr 14, 2015 7:51 pm
Yep, and remember the column is also on a slight angle.
If the column was centred to the seat it would be on a greater angle and you would need a longer right arm. :lol:
PostPosted: Tue Apr 14, 2015 7:52 pm
Mick wrote:
Are you working on the Cooper S Michael?
I've never stopped. :mrgreen:
PostPosted: Tue Apr 14, 2015 7:56 pm
Like continental drift!
PostPosted: Wed Apr 15, 2015 8:02 am
If you guys think a Mini seat is offset heaps, go sit in a Hillman Imp (if you can find one!). :lol:
PostPosted: Wed Apr 15, 2015 9:39 am
Anyone else spot the Subliminal Message here? Just wondering!
PostPosted: Wed Apr 15, 2015 1:27 pm
He didn't like being called 'Mick'?
PostPosted: Wed Apr 15, 2015 5:40 pm
LC/LJ Torana has the pedals offset to the right and the column offset to the left. You don't notice when you are flat out in a forest at night.
Users browsing this forum: Bing [Bot] and 79 guests
