It is currently Wed Jul 16, 2025 4:17 pm
 Post subject: welsh (sp) plugs
PostPosted: Mon Aug 01, 2005 9:00 am
OK Mo blew a welsh plug leaving a gaping big hole in the side of the engine...
I have been advised this is not a problem and all I need to do is flush out the engine (where the water goes round to get any remaining fragments of a disintegrated plug out) and then pop in a new plug.
1. is this correct
2. do I need to "cement" it in, or are these things just plugs
3. If my previous plug has disintegrated in the engine, is there any way to ensure its all cleaned out..???
PostPosted: Mon Aug 01, 2005 9:02 am
did the plug literally pop out?
PostPosted: Mon Aug 01, 2005 9:11 am
mate they just push in.. and yeah flush the engine out for a good while..
PostPosted: Mon Aug 01, 2005 10:39 am
it felll out, but there was no "cup shape" to it, it was just like
a slightly curved 20c piece (but much bigger). and yeah, it was sitting
on the flywheel cover, and a bighole was left :shock:
PostPosted: Mon Aug 01, 2005 3:52 pm
There are two different types of plugs fitted to minis, the cup type and the dish type and one of them is hopeless! Can you guess which one you have?
They don't just push in, they are hammered in. :wink:
When you knock them in it is supposed to flatten them slightly which it supposed to increase the diameter to hold them tight. But it don't work real well!
PostPosted: Mon Aug 01, 2005 4:34 pm
i know how its done. its just we are explaining things to marcello here... he good with car bad. yes he is. :lol:
PostPosted: Mon Aug 01, 2005 4:39 pm
While it is out it is a good time to grab the pressure washer and blow the crud out of the block. :wink:
PostPosted: Mon Aug 01, 2005 5:33 pm
While on the topic of welsh plugs... I've been told that to properly flush the oily crap out of my cooling system I need to remove the welsh plugs. How hard is this to do and is there a writeup of how to do it?
 Post subject: replace em all
PostPosted: Mon Aug 01, 2005 7:16 pm
If one has popped out....you should be suspicious about the others...if it was me I would replace the lot.
Molina...do you have a sharp screwdriver that can be hammered?? Just put the sharp edge in the centre of the Welsh Plug and give it a descent whack...when the screw driver punctures the Welsh Plug you can then wangle the plug out...
clean up the area for the new plug to be drifted in....
PostPosted: Mon Aug 01, 2005 7:25 pm
Last time I saw one of those pop out (kazjim's 998 turbo) it turned out (eventually) that the radiator cap was too long for the rad neck, and wouldn't open under pressure. So the pressure got out thru a welch plug.. and a rad hose... and another rad hose... :cry:
Bought a new cap lately? Make sure it is the right one for your radiator. Oz ones are different length to many UK ones.
PostPosted: Mon Aug 01, 2005 8:11 pm
marcello your rad cap has always been loose
did you replace it recently?
Inconspicuously Conspicuous
PostPosted: Mon Aug 01, 2005 9:56 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
thats the rust demon you need to remove whats left of the old welsh plug then replace it
makka
PostPosted: Tue Aug 02, 2005 7:05 am
Iwannamini
make sure you get the brass cup type non brass rust out quick and do the lot.
Steve
PostPosted: Tue Aug 02, 2005 7:14 am
Steve wrote:
Iwannamini
Steve
Don't forget there's one hiding behind the steady bar... :wink:
 Post subject: Re:
PostPosted: Mon Apr 20, 2015 4:48 pm
Opening a very old topic. but a quick question on the two types of welsh plugs from mini sport.
both below are 1 5/8" the one that came out of my 850 is a dish type can i used the cup type and do they fit better?
http://minisport.com.au/mini-850-1100-w ... type-1-5a8
http://minisport.com.au/mini-1275-coope ... welsh-plug
