It is currently Tue Jul 01, 2025 11:40 am
 Post subject: Finding the diff ratio ?
PostPosted: Sat Apr 18, 2015 5:18 pm
Hi all
I have found out what my diff ratio is but would like some feedback on the process I used.
As I don't have a tachometer or an accurate speedo and didn't want to pull the engine I did the following.
With the car in 4th gear and jacked up on one side I can turn the wheel and with an indicator on the distributor rotor I could count how many times the distributor rotates. Easy :D
Because you are only turning one wheel the differential will halve the ratio !
Because I measuring at the distributor it rotates at half the engine speed !
So, if I turn the wheel 4 full rotations, i (or in this case the wife) could count the number of rotations of the distributor and I would have exactly the diff ratio 8)
Indicator marked in 18 degree segments (0.05 of a rotation).
The wheel marking point to count its rotations.
4 wheel rotations gave me 4.15 rotations of the distributor so I have a 4.15 to 1 ratio, right :|
Are my assumption correct :?
PostPosted: Sat Apr 18, 2015 5:22 pm
Try it again but with the car on the ground and push it in 4th gear.
PostPosted: Sat Apr 18, 2015 5:28 pm
Then it should only be 2 rotations of the wheel to allow for the half speed of the distributor right :|
PostPosted: Sat Apr 18, 2015 5:41 pm
Just wheeled along the driveway and two wheel rotations gave 4.05 at the distributor so allowing for parallax error both results are pretty close to each other.
PostPosted: Sat Apr 18, 2015 6:10 pm
The nearest diff ratio to that would be a 4.1.
Which is a fairly useless road diff in a Mini.
PostPosted: Sat Apr 18, 2015 6:40 pm
Useless is an understatement.
I'm considering something around 3:1. It is an 1100S so it should pull that OK I think.
PostPosted: Sun Apr 19, 2015 12:35 am
Mates runs a 3.1 in his cooper s and it still goes really well.
PostPosted: Sun Apr 19, 2015 9:36 am
I can't comment on how to find your current diff ratio but I do have a 3:1 in my car and I love it. It still has good acceleration and is great on the highway.
PostPosted: Sun Apr 19, 2015 10:50 am
4th gear is 1:1 so whatever your diff ratio is will be 2 x the dizzy rotation since the dizzy rotates at half the engine speed!
With the car in 4th gear and the road wheel turned 1 revolution, the dizzy should have turned 2.05 times for you 4.1:1 diff ratio yeah?
Cheers Shane
PostPosted: Sun Apr 19, 2015 5:10 pm
Thanks Bubbacluby, Kennomini & MiniVLT for the info on diff ratios.
I'll have to chase up a 2.95:1 or a 3.1:1.
Phil
PostPosted: Mon Apr 20, 2015 12:29 pm
Interesting outcome ...hope you pulled the plugs before pushing in 4th :D
PostPosted: Mon Apr 20, 2015 12:38 pm
Why? It will push quite easily in 4th.
PostPosted: Mon Apr 20, 2015 5:53 pm
Oh sorry Mike, didn't allow for your clapped-out, needs new rings, lots of blow-by, low compression engine :P :lol:
PostPosted: Mon Apr 20, 2015 6:03 pm
Yes, pulled the plugs otherwise I might've needed a new ring :(
PostPosted: Mon Apr 20, 2015 7:47 pm
:lol:
Users browsing this forum: No registered users and 126 guests
