It is currently Tue Jul 15, 2025 9:39 pm
PostPosted: Sat Jun 06, 2015 10:03 pm
Hi I've just fitted my big offset contessa rims and tyres so to my mk1 cooper s to the rear. (No flares).
The inside if the tyre (a032s) rub on the spring and the swing arm. Has anyone had this problem and what can be done to rectify??
Any help would be much appreciated
Mike
Small hauling is the way to go
PostPosted: Sat Jun 06, 2015 10:09 pm
Yes. 6mm spacers.
PostPosted: Sat Jun 06, 2015 10:18 pm
Thanks mate where can I buy them??
PostPosted: Sat Jun 06, 2015 10:33 pm
Will 5mm spacers from mini sport be adequate??
PostPosted: Sat Jun 06, 2015 10:40 pm
No idea sorry. I got a pair of spacers with the wheels and can't get the front wheels over the calipers so I don't run them...
PostPosted: Sat Jun 06, 2015 11:02 pm
Thanks
I ground my calipers and they now fit
PostPosted: Sun Jun 07, 2015 1:30 am
Hi Gents, fitting spacers to offset the rims to my knowledge is not legal, best you check with the local RTA State authorities. Grinding the calipers to fit the rims, maybe the rims were not meant to fit, it is a poor practise and not recommended, metal is cast for its inherent strength and not meant to be removed.
PostPosted: Sun Jun 07, 2015 10:33 am
On the rear you could use the integral spacer drums, either Moke or Cooper S/Clubby S ones. Machine the spacer off to get the width wanted. Then, it is legal.
[edit] for the front, it has been suggested in the past that thin spacers are legal IF screwed to the wheel or hub. Just sayin'.
My Fiat 124 sport had 6mm spacers screwed on at all 4 corners, ex factory.
Last edited by drmini in aust on Sun Jun 07, 2015 10:37 am, edited 1 time in total.
PostPosted: Sun Jun 07, 2015 10:37 am
What about the narrowed spaced moke drums
PostPosted: Sun Jun 07, 2015 1:02 pm
Seems obvious to everyone else but..... is a "high offset" wheel the original aftermarket ROH wheel ?? or the later factory wheel (which has less offset).
Being an S one would think it would already have the "spacered" drum (ie the drum includes the integral cast spacer). Both types of rims fit fine on my S (although I've not used A032s).
The aftermarket wheel fits fine over (my) S discs while the factory item does need the caliper to be slightly shaved (near the bleed valve) - and a spacer - IME.
The aftermarket wheels will need flairs while the factory ones don't (juuuust). My factory wheels do fit under the non flaired arch when using a spacered S drum - I'm pretty sure you couldn't use these wheels without the spacer.
Cheers, Ian
PostPosted: Sun Jun 07, 2015 4:53 pm
minis & cooper S`s were originally designed to fit 145 tyres,,, 165 tyres usually rub (on the back) with those offset mags
thin spacer is the go for the rear & attach it to the rim/or/drum via a couple screws if you worry about legalities
the wheel nuts hold the wheels on pretty damn good, :-) can`t see a thin spacer causing problems
unless there`s not enough stud length to suit...
sometimes the rules are stoopid :-)
PostPosted: Sun Jun 07, 2015 7:00 pm
I agree the rule is stupid, look at 1/2 the fwd Jap cars- all that holds the front disc rotor (which is in effect, a `spacer') on is the wheel + the wheel bolts.
But, rules is rules... :roll:
I guess it does stop people fitting those `universal' slotted spacers and screw-on stud extenders you see hanging in parts shops- now THOSE deserve to be banned.
PostPosted: Sun Jun 07, 2015 10:09 pm
The difference is whether it is OEM or not.
If it is OEM, it is fairly safe to consider that someone has done the calculations and design work needed to be sure it not going to cause a problem. The right materials, right length studs and nuts, nothing overloaded, etc.
In the case of grabbing some Chinese made cast alloy spacer things from the local Cheap as Chips... well, you get the picture.
As for those bolt on spacers that change stud patterns and include their own captive studs, they are scary. I hope I'm not even driving alongside something fitted with those!
Don't listen to what I am saying... just understand what I mean.
PostPosted: Sun Jun 07, 2015 10:19 pm
I've used the same rims on my mini K van and had the same issue (with the std drums).
I used a spacer made from a machined off std drum, just the front face left. You can use the std retaining screws to secure it to the drum.
PostPosted: Tue Jun 09, 2015 8:31 am
I have some original type 5" wide Contessa's on my MK1 S with 165/70 10 tyres and they don't rub. I still have the original S drums on the back.
They also fit the front without having to modify the caliper.
If you expect them to fit without guard extensions its not going to work.
Even the original 4.5" steel wheels with 145/78 10 tyres don't fit under the rear guards completely.
RonR
68 build Mk1 Cooper S
