It is currently Wed Jul 09, 2025 8:40 am
 Post subject: rocker shaft hardness
PostPosted: Tue Jun 16, 2015 10:34 pm
how hard are rocker shafts meant to be?
this one has done maybe 1500-2000km, and the end snapped off as you can see...
I took the rest of the shaft out tonight, and it's very soft - one pass over with a semi-circle file will make a mark the size of a tic-tac.
This topic on turbominis has the same, but from 2008 - http://www.turbominis.co.uk/forums//ind ... tid=238138
PostPosted: Tue Jun 16, 2015 10:59 pm
I find the HD shafts from Karcraft are pretty hard.
Stock replacement shafts are soft, not hardened at all. Material unknown. But BMC ones were good steel, probably EN8 or better.
PostPosted: Tue Jun 16, 2015 11:05 pm
Any reason why they're drilled out to such a thin wall?
That looks more like a hardened shaft break, however this can happen in ductile steel (soft) if a load is applied very rapidly. Hardening a shaft is unlikely to alleviate this problem.
Could be rubbish steel too.
PostPosted: Wed Jun 17, 2015 4:44 am
There's also a very recent thread about rocker shafts snapping on the Mk1 forum : http://mk1-forum.net
PostPosted: Wed Jun 17, 2015 8:15 am
A recent HD shaft I got was very poorly drilled and countersunk compared to previous. IMO quality of these is becoming a problem.
