Irish Yobbo wrote:
Also keep in mind that bolting the motor on could pull the case in closer, reducing that clearance. I've never had it happen so this is just hearsay, but be sure to butt the motor hard up against the clutch cover and tighten up the clutchcase-to-motor bolts before tightening the motor-to-gearbox bolts.
In 40+ years I've never seen a gearbox case that wasn't flush with the end of the block when assembled.
I haven't seen it either, but I think the theory is sound. If the gearbox is bolted up first, the side cover gasket isn't compressed against the engine, and could have a few thou of clearance. So when the side cover is then bolted on, it can pull it in a little closer. Not sure if it can really cause issues, but there's no reason not to do the side cover bolts first, just to be sure.
