It is currently Mon Jul 21, 2025 1:33 am
 Post subject: Is this a 1.75 Su ?
PostPosted: Thu Aug 20, 2015 7:54 am
Simonw
Brisbane QLD
1st car - 1964 Mini Panelvan 850
Previous - 1978 Leyland LS 1275 Gold
- 1969 Mini K
 Post subject: Re: Is this a 1.75 Su ?
PostPosted: Thu Aug 20, 2015 8:30 am
Simon,
That is an 1 1/2" SU
HS4
1 3/4" has a square mounting flange with 4 holes.
Dave
PostPosted: Thu Aug 20, 2015 8:55 am
The "1 3/4 inch" refers to the diameter of the carb inlet.... Find a tape measure??
Cheers, Ian
PostPosted: Thu Aug 20, 2015 8:58 am
This is mine, you can see the four square bolt holes to the manifold
PostPosted: Thu Aug 20, 2015 9:09 am
Cheers, Ian
Actually Ian, no, it refers to the carb outlet size.
AN HS6 has a smaller inlet bore than an HIF44 does, but can be machined out for better flow than stock.
PostPosted: Thu Aug 20, 2015 9:13 am
Cheers, Ian
Inlet approx 41mm, outlet approx 44mm
PostPosted: Thu Aug 20, 2015 11:04 am
sitnlo62 wrote:
Simon,
HS4
Dave
Thanks mate , only had the picture so couldn't measure in person..
anybody have a 1 3/4 they would like to sell ..? Pm me :)
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Thu Aug 20, 2015 7:07 pm
Cheers, Ian
Close enough for Government work..... :) Its the principle that counts (ie measure..)
Interesting.. I always thought carbs necked down... Does that mean 6s don't?? The math tells me that 1 3/4" = 44.5 mm
... and the 44 under the bench measures 47(I) and 44 (O)..??? Which I would have known if I'd checked first .. :roll:
Cheers, Ian
Users browsing this forum: Bing [Bot] and 76 guests
