It is currently Tue Jul 22, 2025 12:35 pm
PostPosted: Wed Aug 19, 2015 12:26 pm
Hi everyone,
Fairly new to the hands on stage so this may seem common knowledge, but what's a sure fire way to clean a block before having work done on it. After a degreaser shower, it's still pretty sad.
Once it's all clean and ready for some work, I'll be shipping it interstate (may seem like overkill but when I asked a local engine block place about getting some work done, his words were, "give me a call before you drop it over so I can run the other way. ) Shipping from central qld to Sydney so is there any tricks I should know before shipping an engine (minus gear box).
Cheers for any advice,
PostPosted: Wed Aug 19, 2015 6:36 pm
Use a few metres of builders plastic and duct tape. Engine reconditioning places usually hot tank parts before working on them so I wouldn't get too excited about making it spotless.
PostPosted: Wed Aug 19, 2015 6:54 pm
I've used e-go couriers for shipping car bits. If you can drop it off to their depot it's cheaper
PostPosted: Wed Aug 19, 2015 8:53 pm
Stay away from Engine builders that have such comments about Mini engines. He obviously does not like doing them. Could be a bad move taking it to this person besides waste of money.
"Let us remove your "SHORTS"
PostPosted: Thu Aug 20, 2015 9:55 am
My thoughts exactly , sounds like an arrogant pr!ck :roll: .
PostPosted: Thu Aug 20, 2015 10:42 am
Hope that wasn't GR just being his usual dry-humoured self :!: :lol:
PostPosted: Thu Aug 20, 2015 10:44 am
Definitely not GR, just the local engine block specialist. I'm actually shipping intestate to GR
PostPosted: Thu Aug 20, 2015 11:37 am
I don't know GR , but have spoken to him a couple of times on the phone , definately didn't come across like that , very easy to talk to .
PostPosted: Thu Aug 20, 2015 5:32 pm
He asked his local engine shop in rockhampton and they said let us know so we aren't around. So he is organising to send it intestate to a mini specialist...
As for prep work, you could scrape all the gaskets off and remove the 2 studs and the 2 dowels on the bottom of the block so they don't get lost.
PostPosted: Fri Aug 21, 2015 10:25 am
Would acid dipping or glass bead blasting be appropriate to clean this up?
I'm looking to do the same to my engine when i can actually get this fly wheel pulled off..... anyone got any recommendations of places to send my engine to in Brisbane to get machined?
