It is currently Sun Jul 20, 2025 9:53 am
PostPosted: Wed Aug 05, 2015 9:48 pm
Hi
Does any one have a copy of this service manual
My brake booster will note release pressure and locks the brakes on (all four) and i am stumped to figure out why.
I have had it resleeved and new seals etc. I assembled it and was careful putting back together (so I thought)
I am little stuck. so before I give up and send it off to be looked at I want to at least try and figure out whats wrong. I have built a few of these over the years with out any hassles.
Every other brake part is new and its definantly holding presssure at the booster not the master cylinder.
Thanks in advance
Bernard
PostPosted: Wed Aug 05, 2015 10:37 pm
Bernard - I can send you a copy when I get back from OS in two weeks time, if you can wait that long.
PostPosted: Thu Aug 06, 2015 2:42 pm
This may help:
http://www.pdfph.com/pdf/vh-44-brake-bo ... documents/
PostPosted: Thu Aug 06, 2015 3:34 pm
If it's any help I have the complete disassembly and assembly instructions for the PBR VH44 booster in my Ford XR Falcon factory workshop manual. I can scan and email to you if you need it. (14 pages in total).
1963 Morris 850
PostPosted: Thu Aug 06, 2015 5:31 pm
Hi Winabbey It would great if I can have a copy of this manual
Thanks
Bernard
PostPosted: Thu Aug 06, 2015 5:32 pm
Yes please.
Pm sent. Thanks Bernard
PostPosted: Sun Aug 16, 2015 6:53 pm
I'm interested in finding out what the problem was, any progress?
My car with disk brakes and vh44 booster, has just started doing the same thing, sometimes locking all 4 wheels up, fortunately not at speed or in traffic. I've fixed the problem for now, by disconnecting (and blocking off) the vacuum hose so that i have unboosted brakes, everything is working fine, just greater leg effort to stop.
PostPosted: Sun Aug 16, 2015 7:19 pm
I have had the booster a part and not back on the car as yet.
I have up loaded in the How Too section a very good breakdown on how it all works which has been very helpful. Search for Vh44
Your problem looks like its on the vacum side. I would take off the large C retainer on the bottom of the breather and check the poppet is not jambed.
The other you could check easily is the return valve that goes on the manifold and into the booster body. They can also jamb
Please keep me posted on what you find.
I plan to do write up on a fault finding guide once I get mine sorted
PostPosted: Sun Aug 16, 2015 9:11 pm
PM sent.
PostPosted: Thu Aug 27, 2015 8:06 pm
I bit the bullet or should I say my cheque book has and sent it too a brake place to be repaired.
The guy called me today as I asked to find out what the problem was.
In a nut shell the new diaphram (new old stock) which I have had for sometime is 3mm bigger overall and was jambing holding the piston on.
He did say it took him a while to figure out what the issue was and it wasnt until he took off the large dome whilst under pressure that it released and measured up a new diaphram to compare (I could not have done this on the car easily).
So one step closer.
Kiwiinwgtn
PostPosted: Thu Aug 27, 2015 8:14 pm
Kiwiinwgtn - I dug out my copy of the PBR VH44 Service Manual and note that it's virtually the same as the Ford one. Most of the diagrams have been copied as is but some of the text is different. It's 26 pages. Do you still want copy?
PostPosted: Sun Aug 30, 2015 6:55 pm
Yes please.
Nice to put in my Mini library of knowledge
PostPosted: Mon Aug 31, 2015 10:47 am
The Mini Comprehensive Workshop Manual, dark blue edition TP832, has a section on the PBR VH44JA.
This is in SECTION m BRAKING SYSTEM.
There are 8 pages labelled m-1 to m-8.
It covers dismantling, inspection and re-assembly of the VH44JA booster.
Hope this helps
RonR
68 build Mk1 Cooper S
PostPosted: Mon Aug 31, 2015 2:01 pm
random question from a newbie. is the booster worth it on drum brakes?
PostPosted: Mon Aug 31, 2015 3:10 pm
No. All the servo does is decrease pedal effort.
