It is currently Sun Jul 20, 2025 1:29 pm
PostPosted: Wed Sep 02, 2015 7:40 pm
Going to need a crank or 2 tested and wanted to know the average rate.
Also is it possible to test a block to see how close the water jacket comes to the bore? this is with reference to offset boring and finding an appropriate block....
am i barking up the wrong tree..?
Many thanks
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Wed Sep 02, 2015 7:55 pm
I was quoted 50 here in Adelaide but I think that included hot tanking so possibly a little cheaper if your cranks are shiney and clean?
AFIK you can x-ray blocks in the hunt for cracks and wall thickness but I have no idea who can carry out this sort of work for you.
PostPosted: Wed Sep 02, 2015 7:59 pm
My local crank grinder charged $50 last time. I think his is a black light fluorescent method.
There are other methods:
1. a `ping' test.
Stand crank on end on the floor and tap the top and 2 middle webs sharply with a small spanner. Each should `ring' for a few seconds. Turn crank on end and do the other one.
If it sounds flat, it's probably cracked next to that web. I have someone's 1098 crank with this problem.
2. Dyecheck test (Rocol):
a. Spray crank all over with step 1 cleaner. Wipe dry with clean rag.
b. Spray crankpins and mains with step 2 red dye. Leave sit for 10 mins or so. Hose off and dry.
c. Spray crankpins and mains with step 3 white powder/developer. Let dry, couple of minutes.
Any cracks will show as red lines in the white powder. This test is pretty good. It confirmed the cracked crank mentioned above.
PostPosted: Thu Sep 03, 2015 10:00 am
Thanks doc and 69 .. Will see what the local uses and charges .
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Thu Sep 03, 2015 10:59 am
http://www.chiltonengineering.com.au/
PostPosted: Thu Sep 03, 2015 11:03 am
Thanks TK , I know dave does engineering work ... Just haven't asked him yet haha !
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Thu Sep 03, 2015 11:04 am
What have you have you done there
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Thu Sep 03, 2015 11:06 am
I think I paid about $75 for a mini crank. I think the process was called Magnaflux.
PostPosted: Thu Sep 03, 2015 12:15 pm
Crank crack tests, block boring.
Dave is very knowledgable. He knows Minis. Top bloke.
Users browsing this forum: No registered users and 68 guests
