It is currently Sat Jul 19, 2025 9:07 pm
 Post subject: Quarter glass catches
PostPosted: Thu Oct 01, 2015 11:24 pm
Any hints for tightening the rear quarter glass catches? Mine get blown shut whenever i hit about 50 kph and i can't see any way of tightening them.
PostPosted: Fri Oct 02, 2015 6:22 am
Fit new rubbers. :)
PostPosted: Fri Oct 02, 2015 7:24 am
You could try carefully peening the rivets a bit.
PostPosted: Fri Oct 02, 2015 8:08 am
It is the `spring' in the rubber that holds them open.
been there done that and it fixed both.
PostPosted: Fri Oct 02, 2015 1:28 pm
A tennis ball shoved in the bottom corner was a standard solution way back when....
Cheers, Ian
PostPosted: Fri Oct 02, 2015 7:18 pm
Mine don't have any rubber in them that i can see
PostPosted: Fri Oct 02, 2015 7:25 pm
I'm talking about the window rubbers. It has sponge or something in it which pushes against the glass. This holds the window open because the bit near the front still pushes it, even with window catch opened.
[edit] This assumes you are using the Australian window rubbers. UK Mk1 rubber is different construction (rubbish). I bought some once, a long time ago...
PostPosted: Fri Oct 02, 2015 7:27 pm
Ok, ill check it out. thanks
PostPosted: Sat Oct 03, 2015 7:51 am
I thought the catch was designed to push back to the position where the latch locks open and the wind cant push it in. In other words the latch goes straight and then back past the point of being straight. Once it is there, the wind cant push it closed.
Alec
PostPosted: Sat Oct 03, 2015 10:06 am
Yeah, they do but when the hinge rivets get a little loose it flicks forward and the window will nearly shut for the most part.
PostPosted: Sat Oct 03, 2015 11:53 am
Wot the good Doc says.......
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Mon Oct 05, 2015 6:25 pm
This is exactly what happens to mine
PostPosted: Mon Oct 05, 2015 8:06 pm
I had this issue with my car and I carefully swaged the pivot pins just enough to tighten them and they were back to as good as new.
