It is currently Sat Aug 16, 2025 10:16 pm
Post new topic Reply to topic  [ 151 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11  Next
 Post subject: Re: Project 68mm
PostPosted: Fri Sep 04, 2015 1:06 pm
aaron wrote:
Phil 850 wrote:
What's in all that tea :D
Sugar, Lots and lots of Sugar. :shock:
Sugar makes you fat, but he's not. Please explain....??? :shock:
sugar doesn't make you fat, fat doesn't make you fat, it's fat and sugar together that makes you fat ;)
PostPosted: Sat Sep 05, 2015 1:16 am
TK wrote:
Meth
O
or
Amphetamine :wink:
PostPosted: Sat Sep 05, 2015 3:38 pm
Graham, if I built a 68mm bore 998 (1108?cc) what HP loss would we get? (compared to the 1220, using RE266SS cam).
This motor was going to be a 1220 but the 1098 crank we got is cracked.
PostPosted: Sat Sep 05, 2015 7:13 pm
Vizard says the A series is more efficient in the short stroke version. Here is another question. 68mm bore 998 (1108?) Vs 1098 in same spec, which would perform better?
PostPosted: Sat Sep 05, 2015 7:28 pm
I would say the 1108 as it is closer to a 1 to 1 bore to ratio
PostPosted: Sun Sep 06, 2015 7:58 am
I'd say there is less piston friction with the 1108 (because less conrod angularity), but I'm giving away over 100cc compared to a 1220.
"There ain't no replacement for displacement" (or is there?)
I reckon an 1108 might last longer, 998 is the only common crank I've never seen broken! :)
PostPosted: Sun Sep 06, 2015 8:34 am
I've got a spare 998 crank in the shed if you need a guinea pig...
PostPosted: Sun Sep 06, 2015 9:14 am
I've got 2x 998 ones here. One is out of a `78 van, std/std, has no wear at all. We'll use that. 8)
PostPosted: Sun Sep 06, 2015 5:16 pm
there is, called boost ;)
Rover 214 atm ....
PostPosted: Sun Sep 06, 2015 6:59 pm
Yeah you are right.
Also there's `cubic money'. If you start to breaks things, these 2 go together.
:lol:
PostPosted: Sun Oct 25, 2015 3:08 pm
Hey Graham, what model maniflow headers did you use?
67 Deluxe under going full resto
PostPosted: Sun Oct 25, 2015 5:53 pm
I asked this last week, he uses the med bore Maniflow LCB.
PostPosted: Sun Oct 25, 2015 6:03 pm
Oh dear, worry, worry...
Hi Mattywood
As Kevin said medium bore Maniflow but I used a 1,7/8 OD exhaust pipe 1,3/4 ID
Graham Russell
PostPosted: Sun Oct 25, 2015 6:13 pm
GR wrote:
Hi Mattywood
Graham Russell
I searched the post for maniflow but couldn't find it. Do you know the model number Graham? Is it this one? Aeg376 http://minisport.com.au/mini-lcb-stage-2-extractora-with-special-centre-pipea-maniflow
PostPosted: Sun Oct 25, 2015 6:35 pm
Maniflow med bore LCB, p/no C-AEG365.
Under $200 from Karcraft.
It's the original Maniflow design one, not the one with the funny centre pipe.
Users browsing this forum: No registered users and 267 guests
