It is currently Wed Aug 20, 2025 6:31 pm
PostPosted: Tue Dec 08, 2015 7:45 pm
Hey guys, Not sure where to post this topic. But I'm trying to make my boot all neat and nicer,
Im trying to make some wooden walls and floor than carpet, iv been trying and trying to make a side wall but having no luck just can't get the right shape without it being totally wrong when I transfer it to cardboard.
So need help if someone has a temple would be amazing or even one on the net which I can download
But any help would be great.
PostPosted: Tue Dec 08, 2015 8:19 pm
Not sure if this is what your after but here is my boot for ideas if you like.
it started as a kit from minisport.com.au but I customed it to my liking.
PostPosted: Tue Dec 08, 2015 8:36 pm
Yes that's exactly it. What does the sides look like? They look squared at the bottom
PostPosted: Wed Dec 09, 2015 6:57 am
Holy crap that's a neat boot!!!
I have a problem.. apparently
PostPosted: Thu Dec 10, 2015 8:25 am
yes they are Squared at the bottom.
this is how it started out before I modified it to fit better http://minisport.com.au/mini-full-boot- ... tank-minis
I will be making another one in the Christmas break and happy to make a cardboard template if you can wait that long.
PostPosted: Thu Dec 10, 2015 5:55 pm
Making templates is easy as
Cut a bit of stiff cardboard or what rough shape but too small, then position it where you want with small gaps all the way around next use a large coin or similar and run it around where you want it to go at the same time mark your template where the inside edge of the coin is. you have now marked out your template only 25mm or whatever size your coin was too small now you can mark up a new template from the line you have drawn on your old one plus 25mm cut it out and with a little fettling bob's your uncle
PostPosted: Sun Jan 17, 2016 12:49 am
Still after a panel if someone can help
PostPosted: Sun Jan 17, 2016 8:08 am
Where are you located? I have my templates still from when I did my liner. Though I customised it to suit the way I wanted to put it together.
PostPosted: Wed Feb 03, 2016 5:45 pm
Geelong. Can you please post
PostPosted: Wed Feb 03, 2016 8:02 pm
Any chance i can borrow the template after Dave? Will pay for postage and return postage.
Eiles
PostPosted: Wed Feb 03, 2016 8:43 pm
I'm running short on time at the moment but I may be able to trace them onto paper eventually.
I started with this template, but only used the cured part. I found it was too big so used a 3 mm piece of Ply curved around the tank and traced the profile. I also made it taller so it sat on the floor. And trimmed it around the spare wheel
http://www.theminiforum.co.uk/forums/to ... oot-board/
Then I got the other side right as it was a bit funky aswell.
Then I squared it up and made the back piece to suit my size. Then I did the Base board and front(rear) apron that I curved to match the boot.
It's all out of the car at the moment due to a water leak. But once I get back into it I'll try get some templates of the side boards.
Sorry if this is cryptic!
PostPosted: Wed Feb 03, 2016 9:36 pm
Thanks muchly.
Eiles
Users browsing this forum: Jim1965 and 295 guests
