It is currently Tue Jul 22, 2025 12:57 am
 Post subject: The same, but different!
PostPosted: Wed Dec 16, 2015 10:01 am
I saw this mentioned on another website but didn't see if there was a final outcome..
The statement was that even though the mini had the same shape over the 41 year production run, not one part from the original 1959/1960 model cars was common with the final 2000 year Rover minis (as fitted from the factory).
And maybe a secondary question, which part stayed in production over the entire run (seeing as some went and then came back e.g. hydrolastic)
I'm going to start by suggesting the sump plug and the rear wheel hub...
Photos from http://en.autowp.ru/mini/classic/
PostPosted: Wed Dec 16, 2015 12:13 pm
The front windscreen and rubber
PostPosted: Wed Dec 16, 2015 2:22 pm
The seam cover strips
PostPosted: Wed Dec 16, 2015 2:35 pm
Headlights!
PostPosted: Wed Dec 16, 2015 2:45 pm
The front windscreens were changed, the late cars had built in mirror bases.
9YaTaH wrote:
Headlights!
Headlights were changed, the late ones were self levelling
PostPosted: Wed Dec 16, 2015 2:49 pm
9YaTaH wrote:
Headlights!
Shirley, the self levelling part would be in the bucket, rather then the 7" headlight itself?
[sounds French to me, and you know what they robbed us of!]
PostPosted: Wed Dec 16, 2015 2:54 pm
9YaTaH wrote:
9YaTaH wrote:
Headlights!
Different bucket, lense, retaining ring etc
http://www.minispares.com/catalogues/cl ... px?1~10~95
PostPosted: Wed Dec 16, 2015 3:41 pm
well the front windscreen rubbers is right id say and still the same size screen even if it had a mirror base on it
PostPosted: Wed Dec 16, 2015 3:47 pm
Minispares has a different part number and seal type for cars pre/post 1991
PostPosted: Wed Dec 16, 2015 5:17 pm
Maybe some sort of bracket that had no need to be changed.
During the day I work on English designed cars & on my own time I work on English designed cars....
PostPosted: Wed Dec 16, 2015 7:50 pm
boot lid hinges,rear bumper bar
PostPosted: Wed Dec 16, 2015 8:01 pm
Negative Battery clamp/cable?
PostPosted: Wed Dec 16, 2015 8:26 pm
seam covers
PostPosted: Wed Dec 16, 2015 9:45 pm
Nut on the end of the crank shalf
PostPosted: Thu Dec 17, 2015 6:03 am
There is no nut on the crank, maybe you mean the camshaft? If so I agree probably the same.
Crank has 2 bolts. The clutch one has been changed once at least, and the crank pulley bolt has had a few different lengths.
