It is currently Fri Jul 18, 2025 2:53 pm
PostPosted: Tue Jan 19, 2016 7:19 am
Hey all
I need some hydro fluid for the weekend does anyone in WA have any or know where I can get some in a hurry??
Guessing I won't be able to get it from Minisport in the timeframe as interstate fluid postage will be slow and I live a little out of metro. Any help or ideas much appreciated..... Prefer to get proper stuff that use the 50:50 mix option.
Ta
PostPosted: Tue Jan 19, 2016 4:13 pm
Yes I have some
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Wed Jan 20, 2016 6:50 am
Wow the boys in Perth have woke up, have't seen much of Babes lately, next thing we know boomini will give us an update on his supercharger !!
1972 Leyland Mini Clubman
2000 Honda CBR929RR
PostPosted: Thu Jan 21, 2016 6:29 pm
castrol antifreeze concentrate
PostPosted: Fri Jan 22, 2016 7:00 am
+1 , i done a 70/30 mix with distilled water :wink:
PostPosted: Fri Jan 22, 2016 7:41 am
Online
I use 50/50.
PostPosted: Fri Jan 22, 2016 1:02 pm
+2 for Castrol Anti-Freeze. I use 50/50 mix, the benefit of using anti-freeze in your suspension is that it will stop your radiator from freezing. No, really... it says so on the bottle :)
PostPosted: Fri Jan 22, 2016 5:37 pm
Where can I get that specific one?? I have found radicool but not the one mentioned..... Thanks
PostPosted: Sat Jan 23, 2016 7:40 am
I think from memory i brought it from Supercheap.
PostPosted: Sat Jan 23, 2016 8:38 am
Online
Nulon or Valvoline green glycol concentrate is ok too. Just don't but any pre-mixed lollywater!
PostPosted: Thu Mar 10, 2016 6:12 am
I saw at the local Mini place their mix was 14 parts water, 6 parts methanol, 5 parts glycol
So whats the Methanol for
Just another antifreeze ingredient
I want to make my own brew
1970 MK2 Cooper S
PostPosted: Thu Mar 10, 2016 11:42 am
Yes I have also used 1 part nulon concentrate to 1 part distilled water. Basically a more concentrated mix of coolant.
Edit: another option I have heard is methylated spirit instead of water. Maybe this would lower the freezing point further. Perhaps if you lived in Alaska this may be a consideration.
PostPosted: Thu Mar 10, 2016 2:22 pm
Yes us wa boys are still here... just busy with making our minis fat
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Thu Mar 10, 2016 5:06 pm
I found this info as to what was in this fluid
49% alcohol
49% distilled water
1% triethanolamine phosphate
1% sodium mercaptobenzothiazole
1970 MK2 Cooper S
PostPosted: Thu Mar 10, 2016 7:01 pm
I actually use the antifreeze straight up... whether or not that's a good thing I don't know
49% alcohol
49% distilled water
that's the original recipe... alcohol to stop it freezing, water to make it cheaper, the other 2 ingredients (dunno which is which) is rust inhibitor and something to stop the mechanics drinking it
Users browsing this forum: drmini in aust and 99 guests
