It is currently Sat Jul 19, 2025 8:55 pm
PostPosted: Wed Mar 02, 2016 6:46 pm
http://minikingdomonline.com.au/product ... over-tool/
The best tool to have if you have a pot joint mini
I got mine from mini spares england cause no one here had them when i needed it
Ive used it twice so far just put it between the diff cover and pot joint 2 wacks with a hammer and there off
PostPosted: Wed Mar 02, 2016 7:12 pm
This is my pot joint removal tool. It took half an hour of my time to make and used bits I had lying around.
1963 Morris 850
PostPosted: Thu Mar 03, 2016 8:41 am
drjbeam wrote:
http://minikingdomonline.com.au/product/pot-joint-remover-tool/
For me, my selection of wrecking bars (the blade end) work a treat. There you go, Bob's your uncle, and they're off.
PostPosted: Thu Mar 03, 2016 8:26 pm
I tried that with different bars with no luck when I first noticed the oil seal leaking after calling a few mini mechanics they all told me to do it that way
Then I noticed there was a tool in johns mini king parts catalogue call him with no luck then the part number went in google and got it from England 1 week later its at me door
PostPosted: Fri Mar 04, 2016 7:43 am
DrMini pot joint removal tool, part 1.
Part 2 is a BFH. 8)
