It is currently Mon Jul 21, 2025 8:19 pm
PostPosted: Thu Apr 21, 2016 7:42 am
I haven't restored a Cooper, but is it correct to have your flasher mounted on the bulkhead like that. They are a fragile switch, and not water tight. I would expect them to be under dash mounted like all other minis.
G.
1962 Mini Speed sports sedan
PostPosted: Thu Apr 21, 2016 7:54 am
G.
Yep, thats the correct spot.
1963 997 Morris Cooper
1964 Sunbeam Tiger
1969 Austin 1800
1969 Lancia Fulvia Rallye 1,3S
PostPosted: Thu Apr 21, 2016 8:15 am
Well,
You learn something new every day. Thanks for that.
G.
PostPosted: Thu Apr 21, 2016 9:04 am
OnSafari wrote:
Putting my 997 together and i have a question regarding the regulator wiring, my new loom has the regulator wiring branching from the main harness at the firewall, it then has to run under the fuse box, seem odd to me???
Any pics of original spec setups?
you probably have enough people checking their looms and cars to sort the issue out but.........................er...........I noticed the flasher can is installed where I thought it should go on my 997....aka as per the English cars but I was advised by vintage wiring harnesses and I think perhaps Stephen Dalton (sorry SD) that the Australian assembled cars had a sub-harness for the FL5 to extend the wiring back inside the cabin and place the can on the steering column bracket so the audible "tinking" was heard by the driver.
My 997 had this little plastic sheathed loom and so has this feature.
....you just lost him his insurance bonus!
997
PostPosted: Thu Apr 21, 2016 9:54 am
RNY997 wrote:
... the Australian assembled cars had a sub-harness for the FL5 to extend the wiring back inside the cabin and place the can on the steering column bracket so the audible "tinking" was heard by the driver.
The Mini parts books show a sub-harness for the turn indicator can connection. Also sub-harnesses for the interior roof lamp and the horn.
PostPosted: Thu Apr 21, 2016 11:24 am
I do have a bunch of sub-harnesses, I'll double check. What is the wiring arrangement for the regulator on your 997? I cant wait to see a pic of an original setup.
1964 Sunbeam Tiger
1969 Austin 1800
PostPosted: Thu Apr 21, 2016 12:43 pm
My mistake on the flasher can location, yes i do have a sub harness to relocate it inside the car. I was misled by Parnel & Original Mini Cooper!
1964 Sunbeam Tiger
1969 Austin 1800
PostPosted: Thu Apr 21, 2016 12:53 pm
....and hopefully if its an original sub-harness it has the Bakelite and Formica three pin plug too.
Just quickly...I'm certain my harness breaks the voltage regulator wires out (in cotton braid for about 5 inches) right after the loom passes through the hole in the gusset plate next to the reg.
Must admit your picture of the loom looks rather more suited to a Mk1 Cooper S.
also....don't mean to be nosy but I think your brass brake pipe tee-piece is backwards. I cant quite make out where your master cyl pipe is going into but I think the tee-piece should face the other way and feed the front brakes off the side outlet and the rear brake off the bottom outlet.
I'll go away now.........
997
PostPosted: Thu Apr 21, 2016 1:11 pm
Below is the Mini flasher can extension harness that went into production in March 1961, so presumably would've applied to Morris 850's and subsequent models such as the Cooper. Interestingly it specifies a total length of 60 inches (about 1.5 metres) with black PVC covering over all but the last 3 inches.
PostPosted: Thu Apr 21, 2016 1:28 pm
Thanks Winabbey.
1964 Sunbeam Tiger
1969 Austin 1800
PostPosted: Thu Apr 21, 2016 1:31 pm
[/quote]
I'll go away now.........[/quote]
It heads off to the remotely located brake booster located inside the car under the passenger dash rail.
1964 Sunbeam Tiger
1969 Austin 1800
PostPosted: Thu Apr 21, 2016 3:01 pm
Yep...great place for it. Did mine back in the 80s when restored.
looks great....what car number?
997
PostPosted: Thu Apr 21, 2016 7:29 pm
This my 997 Harness , regulator wires come out in front of gusset going downward then loop up to connect onto regulator
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Thu Apr 21, 2016 7:38 pm
Thanks AJ, that's very helpful.
1964 Sunbeam Tiger
1969 Austin 1800
PostPosted: Thu Apr 21, 2016 10:08 pm
Mine....
997
Users browsing this forum: AWOODY and 67 guests
