It is currently Mon Jul 21, 2025 7:37 am
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat Apr 30, 2016 9:22 pm
MED1.5 roller tips, they are well made and cheaper than Minispares ones.
I would post a link on this tablet if I knew how...! :?
on the Mac now, here is the link-
http://www.med-engineering.co.uk/produc ... rocker-set
Last edited by drmini in aust on Sat Apr 30, 2016 10:13 pm, edited 1 time in total.
PostPosted: Sat Apr 30, 2016 9:38 pm
Ha ha. I was going to do the same as you but I am on my phone in a blackout and having issues with tapatalk and posting links.
PostPosted: Sat Apr 30, 2016 9:41 pm
I suspect they are very expensive...?
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sat Apr 30, 2016 9:44 pm
310 sterling, oops. There goes my budget. By the way, how many rpm is a standard 1100S bottom end safe for?
67 Deluxe
Dry suspension
PostPosted: Sat Apr 30, 2016 9:45 pm
Here is some light reading from another forum. http://www.minimania.com/msgThread/1123 ... io_rockers
PostPosted: Sat Apr 30, 2016 9:54 pm
These are the ones i am putting in my Cooper S. I wanted to bush my S forged rockers but this is easier and will give more lift than the offset bushes. http://www.minispares.com/product/Classic/C-AHT436.aspx
PostPosted: Sat Apr 30, 2016 10:10 pm
Be aware of 2 things re these particular rockers:
1. They are now cast iron, not forged. I had to machine a set on top so the nuts sat flat, the swarf produced was cast iron, not steel.
2. Check the adjusters are not bent by turning them and watching the ball end. I have had 2 sets of these rockers recently, ALL adjusters were bent. Replaced them with a set from sintered rockers. Or use S ones.
PostPosted: Sat Apr 30, 2016 10:15 pm
Thanks. How long have these been cast? I bought mine over 12 months ago.
PostPosted: Sat Apr 30, 2016 10:17 pm
Hi Doc,
If I get a set of those and replace the adjusters with what I have I should be right? I'm getting nervous now....
67 Deluxe
Dry suspension
PostPosted: Sat Apr 30, 2016 10:19 pm
If the motor is fresh and the crank not cracked, 7000.
Mine has a 50 year old EN40B S crank in it, I electronically limit it at 7500 now, I used to use 8000 years ago.
PostPosted: Sat Apr 30, 2016 10:21 pm
deluxe67 wrote:
Hi Doc,
Yeah just check the nuts sit flat on top, one set I bought didn't.
Replace the adjusters and should be fine for road use.
miniDave's 1330 rally motor runs these (cast) rockers for years and they are still working fine.
I have a set of the original (forged) MSC 1.5 ones on mine, they have done over 50,000 miles and are fine. So are the bronze guides still.
PostPosted: Sat Apr 30, 2016 10:26 pm
Is the 1100S bottom end limit really 7000 rpm? Is there any point going for the RE282 cam in that case? Not that I was planning on exceeding 7k really. I just assumed the bottom end would cope with it...
67 Deluxe
Dry suspension
PostPosted: Sat Apr 30, 2016 10:27 pm
I have a set of the LDX ones, yet to fit, recheck carb tune and run. http://www.med-engineering.co.uk/products/cylinder-heads/rockers/med-1-5-ldx-rockers. They are nice bit of gear, and i am pretty sure that they are worth 10hp 500 rpm higher based on willy's dyno results. I had thought i bought them a lot cheaper than 310 quid though, maybe they were on special.
michael
PostPosted: Sat Apr 30, 2016 10:31 pm
This is basically a crank limitation, and i am not 100% sure that you can't go a bit higher rpm. It is not going to make a 9000rpm race motor for example.
Mine is a a 1275LS bottom end which is basically the same crank as the 1100S and whilst i nominally limit to 7000rpm, the RE282 has be fine.
The big danger is if you change down too early and over rev it, the crank will crack.
michael
PostPosted: Sat Apr 30, 2016 11:15 pm
The more you rev a 1275, the shorter its life will be. The blokes with the 9000+rpm $BIG Nb motors rebuild them often. You don't want to have to do this for a road car.
The RE282 cam in mine gives peak power at 7000-7200rpm, on the road I seldom go that far. Unless... :)
