It is currently Sun Jul 27, 2025 9:09 pm
 Post subject: SS mini
PostPosted: Sun Apr 06, 2008 11:37 am
ok.... I've no doubt this has been asked before but......
what does as SS have as standard equipment? how would I tell if an SS was real or not?
Just a thought - I saw a similair thread on LS equipment levels - perhaps this warrents a sticky if there is some sort of consensus on equipment levels
'62 Morris 850 (Marion)
'69 Vanden Plas Princess 1300
'71 Wolseley 1300
'74 Austin 1300 Countryman
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
PostPosted: Sun Apr 06, 2008 11:57 am
A Mini SS will have a compliance plate stamped with Mini SS. Everything else is pretty much bolt on and transferrable except that there will be another bracket for the extra horn that is welded on. Normal Clubbies only have one horn so only have one bracket.
66 Deluxe, 07 Cooper
PostPosted: Sun Apr 06, 2008 3:27 pm
The chassis number on the SS is unique to the SS.
The seventh digit is 3. (The LS is 4)
So if it has a 1 or a 2 it can be a Mini or a Mini S or a Sunshine, a 3 is SS and a 4 is an LS.
PostPosted: Sun Apr 06, 2008 3:32 pm
As for what equipment the SS had as standard, we have a full feature on the SS and LS in the next issue of The Mini Experience.
Only two colours available - Omega Navy metallic and Nutmeg metallic.
Only 500 produced. No idea of the breakdown between colours though.
Watto. :shock:
PostPosted: Mon Apr 07, 2008 1:35 pm
This will pacify you until the next copy of TME comes out Kevan ,
Watto , how concrete is the 500 as I have a couple of old newsclippings here , one says 300 and the other says 500 , did they atart saying 300 and then increase to 500 or did a journo stuff up somewhere at the launch ?
PostPosted: Mon Apr 07, 2008 2:22 pm
Hey Ian,
I love your weights on the corner of the poster.
I've just started reading Clany's Crossing - got a copy from a local 2nd-hand book shop.
Still haven't found a copy of Bet your Life though.
Watto.
PostPosted: Mon Apr 07, 2008 5:49 pm
I thought I'd seen that before Ian - should have known it was yours I guess
so........... I would be right in assuming the SS was born with a 998? and drums?
'71 Wolseley 1300
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
PostPosted: Mon Apr 07, 2008 6:03 pm
In a nutshell yes , it was a special limited edition to boost sales , a "Super S" so to speak , under the extra's listed in the poster above it was a standard 998 drum braked mini S .
PostPosted: Mon Apr 07, 2008 7:00 pm
The idea was to create extra sales and use surlpus parts at the same time.
I love the way that they could make a new model without the expense of new badges. Just whack on an extra S and you have an SS.
It was such a success that they could afford to tool up for the "L" for the LS. (maybe they were running out of S's too quick 8) )
PostPosted: Mon Apr 07, 2008 7:02 pm
watto wrote:
Hey Ian,
Watto.
Watto, I can lend you a copy of Bet your life if you like.
PostPosted: Mon Apr 07, 2008 7:09 pm
I thought it was bootful of right arms you were looking for watto not bet your life ? Bet your life isn't one of Evan Greens better novels but still worth reading , I've got bet your life I can send if you want to read it as well .
PostPosted: Thu Apr 10, 2008 8:52 pm
Yes please!
But I am reading Clancy's Crossing at the moment, so wouldn't be finished with Bet Your Life for a few weeks, if that's OK.
Watto.
PostPosted: Thu Apr 10, 2008 9:01 pm
It`s been said (back in the day) that the vinyl rooves were only fitted to the SSs because a whole batch of them were left outside in a hale storm, totally rooting most of the rooves (roofs?) & hence to reason for the vinyl covering... I`m not an actual witness to the fact but that`s how the story went when i was a young fella in the middle of all the new SS mini hype.
Anyone got any hard evidence or know anyone who was actually there at the time???
PostPosted: Thu Apr 10, 2008 9:11 pm
Yeah , watto was able to debunk that one by talking to someone high up in Leyland at the time . It must be only a regional myth that one , I'd never heard it before joining here .
PostPosted: Thu Apr 10, 2008 9:20 pm
I had heard the story before and have seen an SS with the hail dents under the vinyl. :lol:
There were a few big storms in Sydney in those years and a lot of cars in dealers got damaged. I don't know if Leyland at Enfield got hail damage but my dad had a depot just up the road and it got hit in those storms.
The Ford factory at Homebush got clobbered in one big storm just before the Laser came out. They had all the build up stock sitting outside waiting for the release and then they had to write them off!
