It is currently Sun Jul 20, 2025 12:41 am
Post new topic Reply to topic  [ 58 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Mon Mar 16, 2009 2:31 pm
I know people have people done, used and purchased in regards to trigger wheels for crank shaft pully?
Show me pictures please!
PostPosted: Mon Mar 16, 2009 2:52 pm
I did the one on Benjamin's turbo, also Pristic's turbo.
Pete took some pics of it in his engine build thread.
It used a Falcon trigger wheel with a boss I welded to it. It was more work than Benjamin's but it's mounted by the 2 tapped holes in the harmonic balancer hub. Best way to do it, as it can't creep around on the rubber damper.
Not that I've heard of any doing this, except Holdens.
PostPosted: Mon Mar 16, 2009 2:59 pm
do a search
:P
PostPosted: Mon Mar 16, 2009 3:35 pm
I did a search, only got dodgy pics of Pete's! :lol:
After doc's reply i've decided if I ever needed one i'd pay him to make one up. :lol: :lol:
PostPosted: Mon Mar 16, 2009 5:38 pm
Here are the ones I make for the SC setup
4efte powered Clubman
supercharged 998 race car
PostPosted: Mon Mar 16, 2009 7:43 pm
Yeah that's similar to how mine turned out.
Do not try and tap tiny holes in the hub flange, there is NO metal there to speak of, it's only around 1.0-1.5mm thick, and brittle.
I cut an old one up to find out.
PostPosted: Tue Mar 24, 2009 7:00 am
excuse my ignorance but what do these do?
PostPosted: Tue Mar 24, 2009 11:51 am
These are used as the crankshaft angle sensor when a programable ignition system like a Mega Jolt is fitted. It tells the computer at what degrees the crankshaft is so it can fire the coils at the correct time. This system does away with a distributor and uses 2x two output coils so effectively their is one coil per cylinder.
PostPosted: Wed Mar 25, 2009 11:53 am
that's a nice looking bit of gear Ben ;)
PostPosted: Fri Mar 27, 2009 2:58 pm
tell me about these trigger wheel dealies -
they obviously trigger on the rising edge of each tooth, so the tooth width doesn't matter, but how many degrees apart is each rising edge? - never mind - I counted the teeth on Ben's wheel - 35 teeth plus a space - 10 degrees
how many teeth does it need? I know now...
how does it all work?
I deal with a laser cutter a little bit, and drew one roughly to see what it'd cost to have one cut out - $26-$30 depending on the thickness (I asked for 5 and 10mm) - that was for just 1
PostPosted: Fri Mar 27, 2009 3:07 pm
Forum Graffiti
Have a squiz at this, it's for MSII but it's the same principle :)
http://www.megamanual.com/ms2/EDIS.htm
PostPosted: Fri Mar 27, 2009 6:17 pm
I ve got to make another couple of these up and I was thinking about getting them lazer cut that one I just fully machined.
These are for a Mega Jolt/ Mega Squirt which uses a Ford Edis 36-1 system. So yep needs 35 teeth and the missing one acts a sinc to know where TDC is.
PostPosted: Fri Mar 27, 2009 6:19 pm
Wow, great stuff that just shows how easy it is to setup electronic programmable ignition!
It also shows how easy it would be to add a throttle position sensor and add programmable electronic injection control.
I would love to set an engine up with this, I sense a future project coming on... :)
The 850 Man
PostPosted: Sat Mar 28, 2009 3:05 pm
I figured you'd machined them... must take a while to do each one of those teeth - even with a rotary table
what hourly rate do you value yourself at? :)
PostPosted: Sat Mar 28, 2009 5:16 pm
funnily stumbled across this the other day...
no idea how they compare ....
http://www.sdminis.co.uk/7.html
