It is currently Sat Aug 09, 2025 7:45 pm
 Post subject: Smiths RPM Wiring RVI
PostPosted: Wed Mar 31, 2010 3:20 pm
Has anyone wired one of these up?? Whats the wiring diagram??
Cheers Brett
PostPosted: Wed Mar 31, 2010 3:32 pm
This might help:
http://mk1-performance-conversions.co.uk/technical_electrical.htm
8) In the garage:
1970 Morris Cooper S MK2 | 2010 MINI Cooper JCW Challenge Edition
:( Now with new owners:
1964 Morris 850 Van | 1965 Morris Cooper S MK1 | 1976 Leyland Mini | 1999 Rover Mini Cooper Classic | 2006 MINI Cooper JCW
PostPosted: Wed Mar 31, 2010 5:27 pm
PostPosted: Wed Mar 31, 2010 9:13 pm
kida looks like the same pice of wire that goes from the coil wraps around the distributer
thanks guys! :D
PostPosted: Thu Apr 01, 2010 8:31 pm
In case it isn't clear it's the pink diagram above and the dotted line means the wire between the coil and distributor has been removed. It's been replaced by a long white one that goes from the coil up to the tacho, looping through the plastic block, and then back to the distributor.
Apologies if that was already clear.
PostPosted: Thu Apr 01, 2010 8:49 pm
yeah thanks got it working!! :D Suprise Suprise I double checked with my auto electrican, finished it off at front of the shop during working hours! 8)
