It is currently Wed Jul 23, 2025 2:09 am
 Post subject: 2nd gear crunch!!!
PostPosted: Sun May 16, 2010 9:03 pm
Hey,
Just wondering what would be causing my 2nd gear to crunch when changing from 3 to 2 but only every now and then? Would it be the selector folks?
I was doing a defensive driving course today and towards the end of day going around a track when i would change back into 2 it would clean the teeth a little bit but when i changed slowly into 2nd it would be fine.
So yeh any help would be great
Thanks Blake
PostPosted: Sun May 16, 2010 9:12 pm
Sounds like a fairly typical worn baulk ring and possibly weak springs in the synchro hub.
PostPosted: Mon May 17, 2010 11:21 am
ok thanks. When i got my engine rebuilt by GR he checked the gearbox and the like and replaced anything that was worn and its only done 1000k's since then.
PostPosted: Mon May 17, 2010 12:42 pm
he wouldn't have stripped the main shaft where the synchros are
just teach yourself to double clutch when you down change to 2nd
PostPosted: Mon May 17, 2010 5:15 pm
oh ok so they arent really something thats in plain sight then?
Yeh i can double clutch just have to teach myself to do it while im braking!!!
PostPosted: Tue May 18, 2010 1:20 pm
A little pause in neutral before pulling into 2nd might do it. Give the baulk ring more time to slow the gear down.
As for double clutching, if your feet are big enough you should be able to brake and at the same time roll the right side of your foot onto the throttle for the blip.
Pete
PostPosted: Tue May 18, 2010 2:24 pm
just double check that the clutch is adjusted properly and is not dragging during gear change.
www.minisprintgt.com
PostPosted: Tue May 18, 2010 3:17 pm
Yeh i find it i just wait 2 seconds instead of jamming ti straight in that helps.
Tha clutch adjustment was a thought. Im going to get it checked jsut to make sure.
