It is currently Sun Jun 09, 2024 8:42 am
PostPosted: Wed Feb 24, 2021 10:43 am
Online
Hi all,
I drove the mini home on Monday night and noticed the headlights weren’t working. The front parking lights work, and high beams work too, just not the low beams.
Any suggestions on the first place to start checking things? I’m guessing it’d be the switch on the floor?
Thanks
PostPosted: Wed Feb 24, 2021 11:00 am
Hey timmy I had the same issue a while ago with my clubman. While it may be completely unrelated as I'm not too familiar with the wiring differences between our cars, I ended up finding that it was a wire in the indicator stalk that had broken from the factory solder. Re soldered it and it worked a charm. Might be worth a punt?
-----Better is the enemy of good-----
-1976 Yellow Devil Leyland Clubman-
-1970 Morris Mini Van - Work in progress-
PostPosted: Wed Feb 24, 2021 11:21 am
Online
Thanks Joe. I don’t believe the Mk1 wiring has any headlight wiring going to the indicator stalk, but I did remove the stalk a few months ago and haven’t used the headlights since so it’s worth double checking
PostPosted: Wed Feb 24, 2021 11:48 am
Check the headlamp wire connectors behind the grille. Blue/red is low beam. It might have pulled out.
PostPosted: Wed Feb 24, 2021 2:40 pm
Hey Timmy
I had no lights on one of my cars. Washed out the toggle switch on the dash with electronic cleaner.
Fixed it up good.. Maybe worth a try
Regards Glen
PostPosted: Wed Feb 24, 2021 8:44 pm
I’d say the switch or a loose connection somewhere to the Lo beams. Time to break out the test light.
PostPosted: Wed Feb 24, 2021 8:48 pm
Don't forget to get your globes!
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Thu Feb 25, 2021 5:52 am
I had similar issues with lights working intermittently (able to be switched on, but sometimes not coming on), and having bad earth (one headlight very dim).
My problem was the switch under the floor. All the terminals were thoroughly corroded from water and and also been melting the sound proofing and shorting - burnt crisps all around it.
I would definitely check the floor dipper switch, even just to make sure everything is happy there, as mine seemed rather innocent.
PostPosted: Thu Feb 25, 2021 8:57 am
I guess that’s a reminder for people who have used any foil covered sound proofing to thoroughly check its well clear of the floor switch. There is no fuse on early headlight systems.
PostPosted: Thu Feb 25, 2021 9:14 am
Power goes from the dash switch to the dip switch and then to the selected output.
As your highs are working power is reaching the dipper so the dash switch will be ok.
Rod.
______________________________
'63 Morris 850 (Old Secondhand CAR)
PostPosted: Fri Feb 26, 2021 7:17 pm
Online
Thanks Kev - checked and all OK
OGW1152 wrote:
Hey Timmy
Regards Glen
Thanks Glen, I've checked the switch and I'm getting a nice constant 12V
Globes have been checked too and all OK
Thanks Willko. I pulled the dip switch off the floor and the middle (signal from the switch) terminal was a bit crispy but otherwise OK.
I've checked the dipper switch and it's working OK
Heres the result from the multimeter:
12V to dash switch
12V to dip switch
12V to low beam from dip switch
12V when switched to high beam
0V at the double bullet connector near the grille
Low beam lights up if I use the parking light bullet for power
So quite possibly the worst possible conclusion - a break or burn somewhere between the dip switch and the grille. I think this means it's finally time to add the relay I bought a few years ago and run some new wiring.
PostPosted: Fri Feb 26, 2021 8:54 pm
If you probe along the line using sewing pins or similar you might be able to narrow it down further, I hate wiring with just red or black wires everywhere, so it might enable you to use existing wires from relay to headlights and or dip switch to relay.
Roads need more corners
Users browsing this forum: Drydave254 and 13 guests
