It is currently Sun Jul 06, 2025 2:56 pm
 Post subject: Starlet GT information
PostPosted: Mon Nov 26, 2007 9:20 am
Give Ash some flowers Nick .
With thanks to "clubman77"
clubman77 wrote:
Hey Guys,
Just wanted to share a link to some Starlet GT information I found it looks pretty good.
It appears to be a correlation of a lot or information that can be found on the net.
So here is it:
http://el31.com/starletgt.pdf
Hope this helps some people out. Also it 1.5MB for anyone with a slow ISP.
Isaac
PostPosted: Fri May 22, 2009 3:19 pm
Starlet GT workshop manual:
http://www.jpnz.co.nz/afawcs0131170/CATID=26/SUBID=358/page=1/products.html
-James.
Toyota 4EFTE Powered Minivan.
PostPosted: Sun Aug 23, 2009 2:29 pm
Should've put this here to begin with - instead of starting a new post:
After some reading on the austarlet forum, i've come accross this link. It's bloody awesome for part number references.
http://www.toyodiy.com
Answer the Question....
BUT always Question the Answer
 Post subject: Kaaz Diff Part Number
PostPosted: Wed Sep 16, 2009 4:58 pm
Here is a list of Kaaz diff part numbers
http://www.swmotorsport.com.au/contents/en-us/toyota.htm
PostPosted: Tue Jan 24, 2012 9:11 pm
EP82 Wiring details created by me :)
Contains :
-The wiring loom layout
-A photo, ID of every connector
-Quick reference table for Connector IDs
-Conduction tables for the combination switches (lighting, indicators, wipers)
-Fuse & relay ID's and pinouts
-Wiring diagram of the instrument cluster (for my Gen 1 EP82)
-The configuration of A/C Condenser and radiator fan relays and how they work in conjunction with the coolant temperature sensor and A/C refrigerant pressure switches.
http://www.toyotagtturbo.com/forums/sho ... -available
Direct Link tp PDF : http://www.toyotagtturbo.com/wiki/EP82w ... ectors.pdf
-Alan
