It is currently Mon Aug 04, 2025 2:00 am
PostPosted: Wed Jul 27, 2005 7:00 pm
High heel ninja
The drivers side of my wife's 71 Clubman loses hydro pressure & sags down after a few weeks, i took the skjid plate off today & discovered a small fracture in the pipe, where the pipe bents around the front edge of the floor.
Does anybody know how or someone that could repair the pipe in the car thats in Sydney????. As the thought of dropping down both F&R subframes to put another pipe in makes me want to spew.
Any help/advice will be happily recieved.
Doogie
 Post subject: Sleeves
PostPosted: Wed Jul 27, 2005 7:03 pm
I vaguely remember split sleeves that slide over the tubing...but if it isn't just local damage....and it has split in one place it may be prone to splitting elsewhere.... :idea:
PostPosted: Wed Jul 27, 2005 7:14 pm
Measure the pipe, go to Pirtek or Enzed and get some `swagelok' fittings and some new hydraulic pipe. Then cut the old bit out, slide the fittings etc on, and do up. Instant repair. :wink:
Or take the whole pipe, and they will make you a new one. 8)
PostPosted: Wed Jul 27, 2005 7:28 pm
High heel ninja
Thanks Kev, will investigate 2mrw, removing the pipe is the "LAST" option for me.
Doogie
PostPosted: Wed Jul 27, 2005 7:30 pm
Cut as much pipe out as necessary to get to clean pipe. The fittings won't seal if pipe is crappy.
