It is currently Mon Aug 04, 2025 2:01 am
 Post subject: restoring a mini
PostPosted: Wed Jul 27, 2005 6:48 pm
when restoring a mini, what is the order of operations??
any feedback would be good
:wink:
wigg
Hey, Rocky watch me pull a rabbit outta' my hat...
nothing up my sleeve...
PRESTO!
PostPosted: Wed Jul 27, 2005 7:05 pm
High heel ninja
Thats up to the individual restorer, usually you strip the vechicle, do the body, paint the reassemble & rebuild the stuff as you go. Well thats how i di it anyway.
Doogie
PostPosted: Wed Jul 27, 2005 7:07 pm
First choose how far you would like to go with the shell. There are 2 options. 1 - Leave it on it's subframe and strip the rest (so it's still rolling). 2 - Strip shell completely, and put the shell on to a box frame with wheels.
Fix up shell rust/dents then paint.
Fix up subframes, suspension and brakes, refit.
Do whatever to the engine/gearbox and put back in.
Do the interior.
That's prolly the way i'd do it. 8)
 Post subject: Start at the Start??
PostPosted: Wed Jul 27, 2005 7:13 pm
It would help if you gave us some idea of the current condition of the body....if the car is is a goer then the first thing I would do is remove the battery :!:
If you can't see the ground thats a very good start :D
Then you can decide the order you want to do things....
if it has a brilliant motor, gearbox, driveshafts, brakes and hubs, you could think about leaving them as is and working on the body alone. ...
PostPosted: Wed Jul 27, 2005 7:47 pm
I am restoring my '77 Clubman LS and as it still registed I have been working to getting it past roadworthy. Goes in next Tuesday for that.
Once it does get past, I then intend to take off the old vinyl roof, rub it all down and then get the car resprayed and then new vinyl on the roof.
After that I intend to strip out the inside, get new door covers made, all the seats reupholstered, new roof lining, new soundproofing underlay and new carpets as well as a new dash, maybe a nice woodgrain one.
Later on I hope to put some disc brakes on it as well.
As the mechanical side of the car seem ok I will leave that part until last where I hope to rebuild the motor, getting it rebored, balanced and blueprinted but that is still some time away yet.
