It is currently Sat Aug 16, 2025 2:11 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Mon Sep 12, 2005 7:27 pm
I have a cams approved rear cage, made from alloy. bolt in.
the car is log booked, so it does not matter much, getting the front half made up when I get the right measurements.
anyone got the right measurements for a basic front cage?
thanks.
PostPosted: Mon Sep 12, 2005 7:34 pm
I've been told CAMS no longer will approve alloy cages unless they are existing in car and car is already log booked with them. Is this right?
PostPosted: Mon Sep 12, 2005 7:50 pm
anyone know how to steal aircraft grade titanium from the boeing factory, i reackon that would work well.... 4 grand u say, not too bad i spose considering it will save your life in a roll over or smash, not that i plan on doing that but im sure if i pass on one i will, thats the way my luck goes...
edit: missed the 800 buck thing, no im not keeping the roof lining, dont want any interior trim other then what is essential, another question, what are peoples ideas about flip fronts, work involved, and what they are so good for, or isnt it worth the effort..??
Potato
PostPosted: Mon Sep 12, 2005 8:10 pm
Kevin
This is correct
PostPosted: Mon Sep 12, 2005 8:59 pm
yeah, thats right. mine got logged on the day!!!!!! lucky!
PostPosted: Mon Sep 12, 2005 10:38 pm
brickworx has a bunch of cages lying around... one you may have to clean first after william humped it last friday.... :?
PostPosted: Mon Sep 12, 2005 10:40 pm
Er that was a moke cage, cushy :roll:
PostPosted: Mon Sep 12, 2005 10:54 pm
all i said was a bunch of cages....
cage poker...
PostPosted: Mon Sep 12, 2005 11:00 pm
High heel ninja
A mate & i have built or own cages in the past, had bond roll bars bend up the main hoop, front legs & windscreen brace, all the other bars are straight, you need to buy CDS cold drawn seamless steel, 44 mm in diameter & a minimum of 2.2mm wall thickness. I built a 24 point structual cage from the front strut towers to the rear shock mounts in my commodore rally car for around $500, it survived to roll overs with no damage at all to the cage. i have also built a full steel cage in my mk 2 cooper s, i will get some pics of it up here soon.
Doogie
PostPosted: Tue Sep 13, 2005 7:24 am
or CDW
PostPosted: Tue Sep 13, 2005 9:18 am
meeni, there is a place in Bayswater that is a CAMS approved maker of roll bars and cages.
Brown Davis Motorsport
47 Holloway Drive, Bayswater Vic
(03) 9762 8722
email: [email protected]
