It is currently Sat Jul 19, 2025 7:13 am
PostPosted: Fri Nov 05, 2004 8:42 pm
what needs to be done to take a say 12G940 head to being a head able to be used on a turbod engine
sodium valves etc are these needed
PostPosted: Fri Nov 05, 2004 9:38 pm
Current thinking is no, not needed- there have been cases in UK lately of the heads coming off sodium filled ones.. :shock:
Good race quality S/S ones are the go, according to most turbo jocks.
Main mod to a head for turbo use (apart from porting & valves) is get some volume into the chambers. Around 28cc is usually needed (stock is 21.4cc) to get the C/R down to around 8.0:1.
PostPosted: Fri Nov 05, 2004 9:55 pm
That's a bog amount of Air :?:
PostPosted: Fri Nov 05, 2004 10:20 pm
s/s stanless steel valves you mean
PostPosted: Fri Nov 05, 2004 10:28 pm
Stainless here my friend......
I've got a 12G202 on a 998 Turbo, and I've still got a fair amount to take out of my chambers.... i'm developing it as i go.....
The main aim is to minimise detonation, while maximising chamber filling....
I'm going to remove the "beak" next time, i still feel that its a "hot-spot" .....
Good Luck!!
J
PostPosted: Fri Nov 05, 2004 10:34 pm
Good Luck!!
J
A turdo on a standed head 202head :shock:
The beak must go, even, the beak is removed from Sue' s standed 202 non turbo :?: :idea:
PostPosted: Fri Nov 05, 2004 10:39 pm
mnmn interesting stainless steel valves
double valve springs im quessing
Users browsing this forum: Bing [Bot] and 78 guests
