It is currently Sat Jul 19, 2025 12:50 am
PostPosted: Sat Jan 15, 2005 5:38 pm
Just swapped the oil filter head over to a spin on, 8) Don't know why it took 3 years to do - the first time I just couldn't get the studs out of the block but this time they come out easy as - probably something to do with having the generator out :oops:
The gap at the top of the filter head dampened the good feeling - is all I need a different gasket or is plate or something missing?
David L
PostPosted: Sat Jan 15, 2005 7:18 pm
Yes, it's a totally different shaped gasket, weird shape.
PostPosted: Sat Jan 15, 2005 11:24 pm
i want to do this aswell.
i have the piece that goes from the upper part of the block, and has a pipe running down to the main housing which the spin on must mount to.
what else do i need?
PostPosted: Sun Jan 16, 2005 5:57 am
The gasket, and 2 short 3/8" bolts. The existing long studs you pull out.
PostPosted: Sun Jan 16, 2005 6:27 am
Have you removed the spacer from the block. I know mine was painted and looked like it was a part of the block. Once removed i just used some gasket maker and it works a treat. no leaks at all.
aaron
PostPosted: Sun Jan 16, 2005 8:27 am
Do the Bling Bling before you put it on :D
PostPosted: Sun Jan 16, 2005 9:27 am
i'll give it a go next weekend, thanks diggers :wink:
PostPosted: Sun Jan 16, 2005 10:14 am
Hey that looks great, why didn't I think of that. I almost hate to ask - how long did that take you?
KB
PostPosted: Sun Jan 16, 2005 10:43 am
And thanks to you I have been able to Bling Bling it.
It took me another 3-4 Hours worth of polishing.
I'm now working on another peice of the engine bay and the the Dellorto.
I wish I had a bremill though :x
PostPosted: Sun Jan 16, 2005 12:28 pm
Do you mean a Dremel?
KB's treasure trove of a garage has one of those in the cupboard!
I still think it would take a while with the dremel though (fairly small contact point).
I'm back at work next week, but ring or PM if you want to try it.
KB
PostPosted: Sun Jan 16, 2005 1:16 pm
Yer thats it.....I'll be fine and give the old fingers a work out :lol:
PostPosted: Sun Jan 16, 2005 1:44 pm
**** me gafmo you bling bling everything
i can just imagine you sitting there like a kid for hours on end rubbing and rubbing
btw how did the subframes go
Inconspicuously Conspicuous
Users browsing this forum: Bing [Bot] and 106 guests
