I was just wondering if anyone has ever fitted a Rover master cylinder / booster setup in a Moke?
I have everything here and would like to know what others have done before I pull the angle grinder out.
The problem is with the firewall mount for the master cylinder / booster bracket. It extends too far back for the Moke firewall. This part that extends back has a spring on it to return the brake pedal, and then a hole to put a bolt through in to the firewall. I was thinking of lopping this bit off and using the spring that is normally on a Mini brake pedal, as the Rover one does not have a spring on the pedal pivot.
Pic to come...
Edit/ Pic is here.
