It is currently Sat Jul 19, 2025 4:50 pm
PostPosted: Mon Sep 21, 2009 6:57 pm
I was just wondering if anyone has ever fitted a Rover master cylinder / booster setup in a Moke?
I have everything here and would like to know what others have done before I pull the angle grinder out.
The problem is with the firewall mount for the master cylinder / booster bracket. It extends too far back for the Moke firewall. This part that extends back has a spring on it to return the brake pedal, and then a hole to put a bolt through in to the firewall. I was thinking of lopping this bit off and using the spring that is normally on a Mini brake pedal, as the Rover one does not have a spring on the pedal pivot.
Pic to come...
Edit/ Pic is here.
PostPosted: Mon Sep 21, 2009 8:24 pm
Pic added.
PostPosted: Mon Sep 21, 2009 8:34 pm
I have done it, ill try and find the pic. Works well.
Have a Nice Day.
PostPosted: Mon Sep 21, 2009 9:00 pm
I built the engine for a good friends of mines Moke, 1380, 5 speed, Metro vented discs etc. We used the Rover booster as they work so well. Cant remember exactly what we did to make it fit, but is wasnt hard.
Have a Nice Day.
PostPosted: Mon Sep 21, 2009 9:06 pm
Yer looks like you guys chopped the end off. Cheers!
PostPosted: Tue Sep 29, 2009 6:11 pm
curl that end underneath the booster if possible you still need that extra bolt it does heaps to stop the booster flexing around
Beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
