It is currently Mon Jul 21, 2025 6:21 pm
 Post subject: 74' with an ECU?
PostPosted: Thu Mar 31, 2005 6:26 pm
Hey, I'm totally new to this board, and also from Canada, but I don't know too many other classic Mini BBS'.
I have a question though. I have an old 74 Austin Mini 1000, from Canada, but it would seem that it has an ECU. It is a Hitachi AT87 Control Module. I had my friend take a look at it, and he says it's a later model of ECU, possibly from the mid-90's, due to the technical make up of the internals.
Now. The mini I have is in a whole lot of pieces waiting for restoration, but the motor runs, and so on, but it's carb. not EFI. Is there some sort of carb ECU that I haven't heard of?
Thanks.
HTP
PostPosted: Thu Mar 31, 2005 6:30 pm
welcome welcome. mmmmm wiinnipeg. cold, flat, cold in winter too eh?
throw a few pics our way and i'm sure you'll get a more sensible answer than this one
PostPosted: Thu Mar 31, 2005 6:38 pm
gday canada!
a good international mini site which you could try is www.minimania.com
but this site is the best! :lol:
PostPosted: Fri Apr 01, 2005 1:49 am
Welcome Trefmawr,
It could be a control module for the ignition? other than that, not entirely sure. Post some pics..
Check out this Canadian mini forum:
http://www.miniportal.ca/forums
PostPosted: Fri Apr 01, 2005 7:32 pm
sure it's not a centre point ignition? the can easily be confused with a carb.
Cheers Steve.
1973 south african mk3, 1275 +30 (1300), RE13 cam, hif44, mildy worked head with s sized valves, pulsar dizzy, 1.5:1 minispares forged rockers.
PostPosted: Fri Apr 01, 2005 8:30 pm
Bonjour And welsome to the boards I didn't even know that you could get an ECU for a carb driven motor but as the others have said post some pics and we will probably be able to help you and I agree with the others and what they have said it is probably for the ignition
Pat
_______________________________________________
Team MADMAN/Pat Rogers
