It is currently Mon Jul 28, 2025 12:55 pm
 Post subject: Block skimming
PostPosted: Tue Oct 18, 2005 11:37 pm
what are the reasons for this???
to raise compression??
to make sure the face is flat??
if i did this, wouldnt my pistons rise slightly above the blocks surface..
well thats how it looks for mine..
is that ok if i was going to use a 12G295?
1100 block and pistons.
thanks.
kaden.
1978 Leyland clubman S.
PostPosted: Tue Oct 18, 2005 11:38 pm
Sometimes it is to true the block.
usually always.
For C/R raising, the head is usually shaved to piss, flat tops, etc.
PostPosted: Tue Oct 18, 2005 11:42 pm
It's used to get them flat.
Usually the case with Mini engines is that after a while and some blown head gaskets, between the cylinders erodes a little, causing it to blow head gaskets more often. This has happened to Rodney, even after a head reco.
When rebuilding an engine, it is stupid not to get it shaved flat. If it wasn't done and causes a problem, then the engine needs full pulling down.
You usually don't take enough off the block for the pistons to poke above.
PostPosted: Wed Oct 19, 2005 12:07 am
ahhhh ok....fair enough.
price range for this to be done??
seems like a pricey thing to do..
PostPosted: Wed Oct 19, 2005 12:16 am
I would be guessing the same price as getting the head skimmed. 8)
PostPosted: Wed Oct 19, 2005 12:20 am
Head skim = $40
Use that as a guide :)
PostPosted: Wed Oct 19, 2005 6:43 am
Takes a little more work to clamp block up before machining. I usually charge $50 for Mini blocks... :wink:
PostPosted: Wed Oct 19, 2005 7:55 am
Motor builders like to deck the block to make sure that the head is square to the cylinders as well. Usually done when you open up the bore.
PostPosted: Wed Oct 19, 2005 10:19 am
my engine machinist wanted $50 to do mine. I didn't get it done.
PostPosted: Wed Oct 19, 2005 4:42 pm
Bad JAM. Bad....BAD!! :lol: Cheapskate.... :lol: 8) :wink:
PostPosted: Wed Oct 19, 2005 5:14 pm
just make sure you ask them not to machine the tab where the engine no. is...
i had my new engine all built up and put it, got the car home and when i went for mod plate for the seats the guy asks where my engine no. was :roll:
i wont tell you how i got by that one... :wink:
http://photobucket.com/albums/v684/64morris/
PostPosted: Wed Oct 19, 2005 5:26 pm
Yeah I NEVER take that pad off. But most shops don't give a stuff..."deck it sir? No problem..." :lol:
PostPosted: Wed Oct 19, 2005 5:41 pm
Magic Marker? :lol:
PostPosted: Wed Oct 19, 2005 8:42 pm
close enough :lol:, but it got me through roadworthy and rego with no problems so im happy
PostPosted: Fri Oct 21, 2005 10:00 am
I'm getting a block skimmed as we speak. Get it back next week for engine rebuild so will tell you the price when i pick it up.
Rod Image
